licensing issue when trying to use Sframe?
Kendell
Kendell Altair Community Member
I'm getting the following error message when I try to open Sframe. I'm not sure how to fix it. Can someone please help me?
Welcome!
Answers
  • Matthew_Sauer1
    Matthew_Sauer1
    Altair Employee
    Hello Kendell,
    I'm sorry to hear that you are having issues. Was S-FRAME previously working on your machine, and this error just recently started appearing? I have made a small change to your account, and would ask that you try re-launching S-FRAME, and let us know if you are still unable to gain access?
    Regards,
    Matthew Sauer
    Altair Support
  • Kendell
    thank you so much!!! what ever you did helped!
  • BRusagara
    BRusagara Altair Community Member
    Hi Matthew. I am currently having the same issue Kendell had. Can you please take a look at my account as well and see if everything is in order?
  • Matthew_Sauer1
    Matthew_Sauer1
    Altair Employee
    Hi there,
    May I ask are you using an Academic, or Commercial license of the software?
    If it is the latter, I would suggest reaching out to your Account Manager, and they should be able to get the license number incremented for you. If you have troubles with this, please submit a support ticket, and we can assist further.
    Support - Altair Community
    Regards,
    Matthew Sauer
    Altair Support
Welcome!
Welcome!
