What Steps should I follow to add a Convection and Radiation Thermal load on the Geometry?
Is there any Tutorial available in online which I can follow.
For convection, refer the below tutorial.
https://2024.help.altair.com/2024/hwsolvers/os/topics/solvers/os/extended_surface_heat_transfer_fin_r.htm
Refer the attached files for radiation.
Hi there,
Additional to the information provided by @Rajashri_Saha; you can also check this out; I found it very helpful when I was starting my training on Altair solvers.
Hope it helps!
