I get an license failure when trying to start rapidminer-studio
thore
thore New Altair Community Member
Hi all,
I want to start rapid miner on linux Mint 19.3, but it doesn't work: so, when I run the RapidMiner-Studio.sh in the terminal it stops with the following process:
Exception in thread "main" java.lang.RuntimeException: Product constraint manager could not be initialized!
    at com.rapidminer.RapidMiner.init(RapidMiner.java:746)
    at com.rapidminer.RapidMiner.init(RapidMiner.java:702)
    at com.rapidminer.gui.RapidMinerGUI.run(RapidMinerGUI.java:383)
    at com.rapidminer.gui.RapidMinerGUI.launch(RapidMinerGUI.java:889)
    at com.rapidminer.gui.RapidMinerGUI.main(RapidMinerGUI.java:865)
    at com.rapidminer.launcher.GUILauncher.main(GUILauncher.java:329)
Caused by: com.rapidminer.license.InvalidProductException: Signature verification failed for product!
    at com.rapidminer.license.internal.DefaultLicenseManager.registerProduct(DefaultLicenseManager.java:262)
    at com.rapidminer.core.license.ProductConstraintManager.initialize(ProductConstraintManager.java:192)
    at com.rapidminer.RapidMiner.init(RapidMiner.java:742)
    ... 5 more
My java is on version 8, so I don't know what the reason for this is. Does anyboday have a solution for this? Thanks in Advance!
Thore
Welcome!
  • Marco_Boeck
    Marco_Boeck New Altair Community Member
    Can you please post the content of the ~/.RapidMiner/rapidminer-studio.log file?
    Marco
  • thore
    Hey,
    I cannot find th log file, it is not where the readme.txt suggests to find it.
  • thore
    Hey Scott,
    sadly this article doesn't help me. I am working with Linux mint and I checked all the program files and could not find any log file.
    Thore
  • sgenzer
    sgenzer
    @thore hmm can't help you there. @BalazsBarany is my go-to Linux guy. Maybe he knows?
  • BalazsBaranyRM
    BalazsBaranyRM New Altair Community Member
    I installed Linux Mint 19.3 in a virtual machine. Installed Java 8 and RapidMiner. I didn't get Studio to run, because Java exited at different points with a segmentation fault. I'm not sure if it's just a Java problem, because other applications also crashed a lot.
    However, ~/.RapidMiner was created and had the studio log in it. If you want help, you have to retrieve this file.
    If your system is otherwise stable (doesn't have the problems I mentioned), you could also try the Amazon Coretto JVM 8 distribution. I use that for running RapidMiner on my system.
    Balázs
  • sgenzer
    sgenzer
    thank you @BalazsBarany
  • adrwee
    adrwee New Altair Community Member
    Same thing here and I have tried some different Java versions (8.0.242.j9-adpt by AdoptOpenJDK and 8.0.265-zulu by Azul Zulu. I'm on Debian 10 Bullseye/Sid.
    So far the error is always the same:
    Aug 30, 2020 4:32:51 PM com.rapidminer.gui.safemode.SafeMode launchStarts
    INFO: Found left-behind lock file from last startup at /home/deppi/.RapidMiner/safeMode.lock.
    Aug 30, 2020 4:32:51 PM com.rapidminer.tools.I18N <clinit>
    INFO: Set locale to en.
    Aug 30, 2020 4:32:57 PM com.rapidminer.gui.RapidMinerGUI run
    INFO: Launching RapidMiner 9.7.002, platform ANY
    Aug 30, 2020 4:32:58 PM com.rapidminer.core.license.ProductConstraintManager initialize
    INFO: Initializing license manager.
    INFO: Using default license location.
    INFO: Registering default product.
    Aug 30, 2020 4:32:58 PM com.rapidminer.gui.RapidMinerGUI main
    SEVERE: Error while starting up RapidMiner Studio. Controlled shutdown.
        at com.rapidminer.RapidMiner.init(RapidMiner.java:738)
        at com.rapidminer.RapidMiner.init(RapidMiner.java:691)
        at com.rapidminer.gui.RapidMinerGUI.run(RapidMinerGUI.java:419)
        at com.rapidminer.gui.RapidMinerGUI.launch(RapidMinerGUI.java:961)
        at com.rapidminer.gui.RapidMinerGUI.main(RapidMinerGUI.java:932)
        at com.rapidminer.launcher.GUILauncher.main(GUILauncher.java:320)
        at com.rapidminer.RapidMiner.init(RapidMiner.java:734)
        ... 5 more
    I will see if the Coretto Amazon JVM will help, and if it does I'll report back here.
Welcome!
Welcome!
