This describes how to change the default folder paths for the following files:
      Prerequisites:
A Monarch restart is required for the following changes to take effect.
      1.)  Open Monarch Classic.
    2.) In the Home tab, select Options.
     3.) Select the Folder icon.
       4.)  In the Folders window, click in the Default Folder path and edit the path for each of the files listed.
     5.)  Click Accept when done.
Note: Changes are made when you restart Monarch.
