Overview
 PREFACE
 Physical vehicle testing is expensive and resource intensive. Vehicle modeling and simulation provide an efficient alternative which can be implemented earlier in the design cycle to understand a vehicle’s dynamics. Multibody dynamics software such as Altair MotionSolve allows users to set up and analyze a wide range of dynamic systems, including vehicles. Altair’s MotionSolve allows the simulation of a large selection of vehicle events to analyze vehicle performance parameters. Results can be used to refine vehicle design and improve occupant comfort.
 INTRODUCTION
 In this model, a Sedan drives over a Belgian block road surface. The tires are modeled using Altair’s proprietary enhanced FIALA tire model which uses an elliptical cam contact method to accurately predict forces despite rough terrain. The goal of the model is to analyze the displacement of the suspension over time allowing the estimation of rider comfort.
Pre-Requisite
SOFTWARE REQUIREMENTS
 - MotionView (2023 or newer)
- MotionSolve (2023 or newer)
MODEL FILES
 - Belgian Blocks Zip (See Attachments)
MODEL SETUP
 - Enable vehicle tools in extensions. File > Extensions > Vehicle Tools
- Enable Entity Browser, Entity Editor, and Model Browser under the View tab.
- Under the Vehicle Tools tab, click assembly to create a vehicle. Use the default settings unless specified otherwise.
 Page 1: Full vehicle with driver
 Page 2: Front wheel driver
 Page 3: Front suspension – Frnt SLA susp (1 pc LCA)
 Rear suspension – Rear twistbeam susp
 Page 4: Default options
 Page 5: Front shocks – Frnt shock absorber (with cylindrical jts)
 Rear shocks – Rear shock absorber (with cylindrical jts)
 Pages 6-10: Default options
 Page 11: Click finish
- Update the tire properties.
- In the Model Browser, select the front tires under AutoTires > Tires.
   - In the Entity Editor, update the tire property file to the fiala_tire_with_cam_contact.tpf file included in the Belgian Blocks zip. Whenever making a file selection, ensure the correct file type is being searched for.
- In the Entity Editor, update the road property file to the Belgian_Blocks_Road.crg.
- Repeat steps i-iii for the rear tires.
- Add a road graphic. - Select the Road Tools icon to create a road graphic. Select the Belgian_Blocks_Road.crg file and hit ok.
- Update the road graphic orientation.
-  Add a road event. - In the Entity Browser follow VehicleTools > Events > Car & Truck and select RoadCourse.
- Select the RoadCourse in the Model Browser.
- In the Entity Editor, update the path profile to road centerline.
- In the Entity Editor, under road settings, change road selection to road file and update the road file to Belgian_Blocks_Road.crg.
 SIMULATION STEPS
 - The model is now ready to run. Open the run dialog, select an output directory, select run offline, and hit run. MotionSolve will run a static and transient analysis.
- After the simulation is completed, select results in the new window to view the animation. Alternatively, open run history next to the run icon, navigate to the model’s name, and select animate.
- A report detailing many vehicle performance metrics can be generated by clicking report in MotionView and selecting the run.
Post-Requisite
RESULTS
 After running the simulation, the motion of the vehicle can be viewed in MotionView or opened in HyperView for more analysis options. Outputs created in MotionView can be viewed as plots in HyperGraph. For example, shock displacements can be plotted over time. The data obtained from the analysis can be used to inform design revisions. For example, it could be useful to test different damper settings, spring rates, geometry or weight distribution to improve vehicle performance and comfort.
 Sedan motion on the Belgian block road.
 Sedan motion side view.
 Displacement of the vehicle from the center of the road.
 Front shock displacements over time.
 CONCLUSION
 In this article, we learned how to set up a basic vehicle model. Implementation of tire and road files allowed the simulation of rough terrain, in this case a Belgian block course. After performing the analysis, the animation can be viewed, and a wide array of vehicle data can be plotted. The results can be used to inform design changes to improve vehicle performance and rider comfort.
 AUTHORS
 John Dagg, Systems Engineering Intern
 Chris Fadanelli, Solution Engineer - Systems Integration
 Ananth Kamath Kota, Global Technical Manager - Systems Integration
