I am examining the fatigue that occurs when a thin metal plate hits another metal. I modeled the thin metal plate with shell elements (The shell element properties I use are attached.) and I used M1_Elast metarial card.
For simulate this impact motion, I'm making a time-dependent solutions with radioss solver. I transfer it (.h3d ) to hyperlife with an upload type "transient response" and I study high cycle fatigue (SN approach) . The life output I get is a very low value like e-2.
For the scenario I mentioned;
- What should be the shell element properties ? What do you recommend?
- Why is the life value so low? (I thought it might be because I use the M1_Elast material.)
- How should we determine "stress combination" in Hyperlife?
Thank you.
Best Regards,
Ovunc
