Altair RISE
Nominate Yourself Now!
Problem with the results of HyperGraph
User: "Sujay Pattiwar"
Altair Community Member
Updated by Sujay Pattiwar
I am performing a Direct Frequency Response Analysis on a Flat Plate for practice. I have requested the results for three nodes. But when I click on OptiStruct the software throws me directly to HyperGraph instead of HyperView. Even when the HyperGraph is opened the results are shown for a single node only instead of three nodes.
I am using a student version of HyperWorks for this analysis.
PFA of the model file of the Problem Statement
Thank You.
1 - 4 of 41
    User: "Rogerio Nakano_21179"
    New Altair Community Member
    Updated by Rogerio Nakano_21179
    Hi
    Likely you are opening the session *.mvw created as the analysis of OptiStruct is finished. With that, each node data is saved in separated pages.
    Likely you have three HyperGraph pages, one for each node.
    if you want to see the model in HyperView. You can add a page and load the *.h3d file generated by the analysis.
    I hope this helps you.
    Regards
    User: "VENKATA SAI KUMAR MADALA"
    Updated by VENKATA SAI KUMAR MADALA
    The same problem is occurring for me while performing frequency response analysis problems. You can see in the images. When analysis is completed by clicking on results it directly opening in hypergraph and i cant able to see the displacement in HyperView also. Also cant able to open .mvw file in hyper graph. could any one help me to resolve it and fix that issues?
    OP
    Hi
    Regards
    Hello Sir, Actually I'm getting only one result, when I try to open the *.mvw file the HyperView closes itself. I'm using a student version of HyperWorks. Is this the problem with the student version?
    User: "Rahul_P1"
    Altair Employee
    Updated by Rahul_P1
    You have to click on View
     and then choose the required result file before clicking on the results button
    you can also open HyperView and then open the result file from the run location as well
