Altair RISE
Nominate Yourself Now!
Error # 332
User: "Altair Forum User"
Altair Employee
Updated by Altair Forum User
Hey guys,
i'm working on a composite component and get the following massage after starting OptiStruct:
NOTE # 9199
 MSGLMT=BRIEF is active, following messages will be suppressed:
 741 742 1935 1052 1305 1436 1437 1051 1931 1932 2010
 Use MSGLMT=STRICT (e.g. in config file) to turn back full printing.
 *** WARNING # 1570
 for material id =         1 referenced from property id =         1.
 Required strength parameters have not been provided or are zero for composite
 material with requested failure index calculation. Failure index will not
 be calculated.
 *** ERROR #  332 ***
 RBE3 element       112636 has singularities - check element data
 *** ERROR #  332 ***
 RBE3 element       112637 has singularities - check element data
 *** ERROR #  332 ***
 RBE3 element       112638 has singularities - check element data
 Number of bad RBE3 elements =        3
FINITE ELEMENT MODEL DATA INFORMATION :
  Total # of Grids (Structural)        :    112960
  Total # of Elements                  :    112629
  Total # of Rigid Elements            :         9
  Total # of Rigid Element Constraints :       738
  Total # of Local Coordinate Systems  :         2
  Total # of Degrees of Freedom        :    662202
  Total # of Non-zero Stiffness Terms  :  18107343
  Element Type Information
   CQUAD4   Elements   :   111849
   CTRIA3   Elements   :      780
  Load and Boundary Information
   FORCE Sets        :         1
   SPC   Sets        :         1
  Material and Property Information
   PCOMP(G)(P) Cards :         1
   MAT8   Cards      :         1
 ***** ERROR ENCOUNTERED BEFORE COMPLETING THE CHECK RUN *****
 Current Memory (RAM)                                    :     216 MB
 Estimated Minimum Memory (RAM) for the check run        :     219 MB
 This error occurs in module 'prpdrv'.
RESOURCE USAGE INFORMATION
 MAXIMUM MEMORY USED                                       216 MB
 MAXIMUM DISK SPACE USED                                     1 MB
COMPUTE TIME INFORMATION
 EXECUTION STARTED                         Fri Mar 07 00:15:17 2014
 EXECUTION COMPLETED                       Fri Mar 07 00:15:23 2014
 ELAPSED TIME                                         00:00:05
 CPU TIME                                             00:00:03
 *** PROGRAM STOPPED: FATAL ERROR(s) ENCOUNTERED.
                        ***** END OF REPORT *****
 For Useful OptiStruct Tips and Tricks, go to the URL:
 There were 3 error messages during input processing.
  The first message is repeated below:
  *** ERROR #  332 ***
 ==== End of solver screen output ====
 ==== Job completed ====
what does that mean and what have i got to do, that i can run the simulation successfuly.
I'm very glad if you can help me!!!
1 - 4 of 41
    Altair Employee
    OP
    Hello,
    please check your RBE3 elements, as stated.
    Set all trans dofs to 1, all rot dofs to zero, all weights to 1. Check if there any free ends, or dependecies.
    Regards,
    Mario
    Altair Employee
    OP
    I am facing a similar issue, but with a different element type
     *** ERROR #  722 ***
     An invalid rigid element.
     This RBAR is not connected with any structural element.
         RBAR element id =   93759525
     independent grid id =   92382982
       dependent grid id =   91905147
     Note: If this rigid element is also connected with other rigid elements,
     then this error means that there is rigid body mode or mechanism remained
     in this rigid element chain due to lack of connected structural elements.
     *** INFORMATION #  743
     The total number of rigid elements, whose rotational dependent d.o.f.
     are removed because there is no need to constrain those d.o.f., is      5098
     *** INFORMATION #  744
     The number of autospcs that will be created to remove the rigid body
     rotation in RBAR and RBE2 is       1931
      Total # of Grids (Structural)        :   988838
      Total # of Elements                  :   386052
      Total # of Rigid Elements            :    22408
      Total # of Local Coordinate Systems  :      424
       CBEAM    Elements   :      162
       CHEXA    Elements   :   307442
       CTETRA   Elements   :    71392
       CPENTA   Elements   :       90
       CQUAD4   Elements   :     6179
       CTRIA3   Elements   :      355
       CBUSH    Elements   :      432
       SPC   Sets        :        1
       PBEAM  Cards      :        2
       PSOLID Cards      :       20
       PSHELL Cards      :       35
       PBUSH  Cards      :       23
       MAT1   Cards      :       26
     Current Memory (RAM)                                    :    1372 MB
     Estimated Minimum Memory (RAM) for the check run        :    2170 MB
    Any suggestions ?
    User: "Rahul Rajan_21763"
    New Altair Community Member
    Updated by Rahul Rajan_21763
    The independent node of rigid element is either connected with other rigid element as a dependent node.
    Plz check.
    Altair Employee
    OP
    Hi Rahul,
    Thanks for your reply.
    The rigid (RBAR) in question is acting as a contact between 3 layered shell structure, I have attached an image of the FEM scenario. The Model has run successfully for NMA [NASTRAN] but in optistruct is throwing error for all the RBAR location.
    There is also issue about the RAM memory :
    My Sys. Config is :
