🎉Community Raffle - Win $25
Join and Win
Error # 332
User: "Altair Forum User"
Altair Employee
Updated by Altair Forum User
Hey guys,
i'm working on a composite component and get the following massage after starting OptiStruct:
NOTE # 9199
 MSGLMT=BRIEF is active, following messages will be suppressed:
 741 742 1935 1052 1305 1436 1437 1051 1931 1932 2010
 Use MSGLMT=STRICT (e.g. in config file) to turn back full printing.
 *** WARNING # 1570
 for material id =         1 referenced from property id =         1.
 Required strength parameters have not been provided or are zero for composite
 material with requested failure index calculation. Failure index will not
 be calculated.
 *** ERROR #  332 ***
 RBE3 element       112636 has singularities - check element data
 *** ERROR #  332 ***
 RBE3 element       112637 has singularities - check element data
 *** ERROR #  332 ***
 RBE3 element       112638 has singularities - check element data
 Number of bad RBE3 elements =        3
FINITE ELEMENT MODEL DATA INFORMATION :
  Total # of Grids (Structural)        :    112960
  Total # of Elements                  :    112629
  Total # of Rigid Elements            :         9
  Total # of Rigid Element Constraints :       738
  Total # of Local Coordinate Systems  :         2
  Total # of Degrees of Freedom        :    662202
  Total # of Non-zero Stiffness Terms  :  18107343
  Element Type Information
   CQUAD4   Elements   :   111849
   CTRIA3   Elements   :      780
  Load and Boundary Information
   FORCE Sets        :         1
   SPC   Sets        :         1
  Material and Property Information
   PCOMP(G)(P) Cards :         1
   MAT8   Cards      :         1
 ***** ERROR ENCOUNTERED BEFORE COMPLETING THE CHECK RUN *****
 Current Memory (RAM)                                    :     216 MB
 Estimated Minimum Memory (RAM) for the check run        :     219 MB
 This error occurs in module 'prpdrv'.
RESOURCE USAGE INFORMATION
 MAXIMUM MEMORY USED                                       216 MB
 MAXIMUM DISK SPACE USED                                     1 MB
COMPUTE TIME INFORMATION
 EXECUTION STARTED                         Fri Mar 07 00:15:17 2014
 EXECUTION COMPLETED                       Fri Mar 07 00:15:23 2014
 ELAPSED TIME                                         00:00:05
 CPU TIME                                             00:00:03
 *** PROGRAM STOPPED: FATAL ERROR(s) ENCOUNTERED.
                        ***** END OF REPORT *****
 For Useful OptiStruct Tips and Tricks, go to the URL:
 There were 3 error messages during input processing.
  The first message is repeated below:
  *** ERROR #  332 ***
 ==== End of solver screen output ====
 ==== Job completed ====
what does that mean and what have i got to do, that i can run the simulation successfuly.
I'm very glad if you can help me!!!
