🎉Community Raffle - Win $25
Join and Win
Shell Thickness Output in SimLab
User: "AndreaFORM"
Altair Community Member
Updated by AndreaFORM
Dear All,
I'd like to calculate and output the thinning of SHELL elements during a Structural simulation in SimLab.
In HyperMesh (Optistruct) this is done using the output card THICKNESS (https://2021.help.altair.com/2021.1/hwsolvers/os/topics/solvers/os/thickness_io_r.htm)
Is it possible to do it in SimLab too?
Many thanks,
Andrea
1 - 4 of 41
    User: "Adriano_Koga"
    Altair Employee
    Updated by Adriano_Koga
    Hi,
    this THICKNESS card is not targetted for thinning of the part during the analysis. It is targeted for Optimization purposes (parametric and free-size), where the design variable is the thickness of the part/elements.
    There used to be a THIN output for thinning, but this was an old integration to Radioss run, if I recall correctly, and this is not used anymore.
    Altair Employee
    Accepted Answer
    Hi,
    i take it back...thickness variation is indeed available for LGDISP run, requesting THICKNESS output.
    In SimLab you could add it as 'Text Data'
    Altair Employee
    thanks to @Kristian Holm for poiting it out.
    User: "AndreaFORM"
    OP
    Thank you Adriano, that's what I was looking for!
