Altair RISE
Nominate Yourself Now!
Composite
User: "tiago3008"
Altair Community Member
Updated by tiago3008
Hi,
For some reason, that i don´t know, it is not openning the  solver window.
1 - 3 of 31
    User: "Simon Križnik"
    Updated by Simon Križnik
    Hi,
    always review the out file for warnings and errors:
     *** ERROR # 772 ***
     It is invalid to use a free grid as an independent grid in RBE3 data.
     Free spiders are not allowed to be independent grids in RBE3 data.
                    RBE3 id =     5082
               free grid id =        2
        weighted components =      123
     You should remove this grid from the RBE3 data.
    Use Tools>model checker>Optistruct to find modeling errors & warnings and apply autocorrection. Or use Check Elems Panel (F10)>1D>free 1d nodes.
    User: "tiago3008"
    OP
    Thank you.
    Others two questions:
    1- I want do simulate a bidirectional, how i simulate that? If i put E1 and E2 equal, means that it is bidirectional?
    2- I also want simulate the resin between the plys. I consider it is MAT1?
    Glad to help.
    1. Yes.
    2. In ply based modeling the resin and fiber material properties are usually homogenized on a ply level. Multiscale Designer can be used to model the composite behaviour at the constituent scale.
