For some reason, that i don´t know, it is not openning the solver window.
always review the out file for warnings and errors:
*** ERROR # 772 *** It is invalid to use a free grid as an independent grid in RBE3 data. Free spiders are not allowed to be independent grids in RBE3 data. RBE3 id = 5082 free grid id = 2 weighted components = 123 You should remove this grid from the RBE3 data.
Use Tools>model checker>Optistruct to find modeling errors & warnings and apply autocorrection. Or use Check Elems Panel (F10)>1D>free 1d nodes.
https://insider.altairhyperworks.com/wp-content/uploads/2017/09/T-T-1248-HyperMesh-Model-Checker.pdf
Thank you.
Others two questions:
1- I want do simulate a bidirectional, how i simulate that? If i put E1 and E2 equal, means that it is bidirectional?
2- I also want simulate the resin between the plys. I consider it is MAT1?
Glad to help.
1. Yes. 2. In ply based modeling the resin and fiber material properties are usually homogenized on a ply level. Multiscale Designer can be used to model the composite behaviour at the constituent scale.
