Composite
tiago3008
tiago3008 Altair Community Member
edited October 2020 in Community Q&A
Hi,
For some reason, that i don´t know, it is not openning the  solver window.
Welcome!
Answers
  • Simon Križnik
    Simon Križnik Altair Community Member
    edited October 2019
    Hi,
    always review the out file for warnings and errors:
     *** ERROR # 772 ***
     It is invalid to use a free grid as an independent grid in RBE3 data.
     Free spiders are not allowed to be independent grids in RBE3 data.
                    RBE3 id =     5082
               free grid id =        2
        weighted components =      123
     You should remove this grid from the RBE3 data.
    Use Tools>model checker>Optistruct to find modeling errors & warnings and apply autocorrection. Or use Check Elems Panel (F10)>1D>free 1d nodes.
  • tiago3008
    edited October 2019
    Thank you.
    Others two questions:
    1- I want do simulate a bidirectional, how i simulate that? If i put E1 and E2 equal, means that it is bidirectional?
    2- I also want simulate the resin between the plys. I consider it is MAT1?
  • Simon Križnik
    edited October 2019
    Glad to help.
    1. Yes.
    2. In ply based modeling the resin and fiber material properties are usually homogenized on a ply level. Multiscale Designer can be used to model the composite behaviour at the constituent scale.
Welcome!
Welcome!
