Altair RISE
Nominate Yourself Now!
STOP : ZERO OR NEGATIVE VOLUME FOR 3D-ELEMENT
User: "Altair Forum User"
Altair Employee
Updated by Altair Forum User
I have received this error message. I read that I have to do the following settings for proprty of plastic
<?xml version="1.0" encoding="UTF-8"?>2015-12-29_15-34-31.thumb.png.4b19060faf
I have activated the ENG/DT/BRICK CST as well and set Tscale and T min as follwing (are the valuses for Tscale and T min correct?) but I still get the same error. Would you please check my attached model and see what is wrong? Thanks a lot in advance
<?xml version="1.0" encoding="UTF-8"?>2015-12-29_15-39-15.thumb.png.9df1ab9962
1 - 3 of 31
    Altair Employee
    OP
    Hi,
    Please refer to the following posts:
    Altair Employee
    OP
    Thanks for your reply Prakash. I am using Radioss block 120 and I am using Hexa elements. So I read the posts you have refered before but they didn't help. I have used M36 Plas TAB plastic and I have used P14 SOLID as card image. What should be the values for
    ISOLID ?
    Ismstr ?
    Icpre ?
    I have activated DT/Brick/CST in control card what shoulbe the values for Tscale and Tmin
    is it ok to use hexa elements here or do I have to switch to tetra. (As I read before tetra elements are stiffer than hexa. Does it help to switch to tetra?)
    Thanks for your help
    User: "Rahul Rajan_21763"
    New Altair Community Member
    Updated by Rahul Rajan_21763
    See this video on 3D elements from our Free crash Ebook.
    https://altair-2.wistia.com/medias/9ahjo4tqz8
    Regards
    Rahul R
