🎉Community Raffle - Win $25
Join and Win
STOP : ZERO OR NEGATIVE VOLUME FOR 3D-ELEMENT
I have received this error message. I read that I have to do the following settings for proprty of plastic
<?xml version="1.0" encoding="UTF-8"?>2015-12-29_15-34-31.thumb.png.4b19060faf
I have activated the ENG/DT/BRICK CST as well and set Tscale and T min as follwing (are the valuses for Tscale and T min correct?) but I still get the same error. Would you please check my attached model and see what is wrong? Thanks a lot in advance
<?xml version="1.0" encoding="UTF-8"?>2015-12-29_15-39-15.thumb.png.9df1ab9962
1 - 3 of 31
