Altair RISE
Nominate Yourself Now!
not found mpich2mpi.dll
User: "FrankSu"
Altair Community Member
Updated by AltairLiz
Hello everyone,
When I use AcuSolve Job Launcher 2020, my job can run normally,
but now I have two jobs to run continuous, I use a batch file to execute,
here is my batch file content:
CD D:\Analysis\run_xxx1
call "C:\Program Files\Altair\2020\hwcfdsolvers\acusolve\win64\bin\acuRun.bat" -pb xxx1 -inp xxx1.inp -np 4
CD D:\Analysis\run_xxx2
call "C:\Program Files\Altair\2020\hwcfdsolvers\acusolve\win64\bin\acuRun.bat" -pb xxx2 -inp xxx2.inp -np 4
when I execute this batch, the system will comes out a warning message "not found mpich2mpi.dll"
Dose anyone know how to fix it? please.
Thank you
1 - 6 of 61
    User: "acupro"
    Altair Employee
    Updated by acupro
    My first thought is that you issuing this from a command prompt that does not have the AcuSolve environment established.  You have two choices:
    1.  Issue this from the AcuSolve Command Prompt - which should appear under Altair 2020 from the Windows Start menu.
    or
    2.  From any Command Prompt first run the script to establish the AcuSolve environment.
    "C:\Program Files\Altair\2020\hwcfdsolvers\acusolve\win64"\bin\acusim.bat
    or the equivalent as you type out that path - maybe the quotes will be slightly different.
    In either case, before you launch your run script, make sure your command prompt 'knows' acuRun, by trying:
    acuRun  -h
    This will tell you whether or not the environment is established correctly.  Once that is confirmed, you can modify your script to:
    cd D:\Analysis\run_xxx1
    call acuRun -pb xxx1 -inp xxx1.inp -np 4
    cd D:\Analysis\run_xxx2
    call acuRun -pb xxx2 -inp xxx2.inp -np 4
    As a side note, Altair Simulation 2021 has now been released, so you could update to the latest version.  The same process will still apply.
    User: "FrankSu"
    OP
    Updated by FrankSu
    Thanks a lot, @acupro
    I used the 2nd method, and it works.
    But as a side note, I tried to increase 1st row to execute acusim.bat in my batch file, like following
    call "C:\Program Files\Altair\2020\hwcfdsolvers\acusolve\win64\bin\acusim.bat"
    then I executed the batch file,
    the Command Prompt seems stop while it after executing first row, like the image below.
    User: "acupro"
    Altair Employee
    Updated by acupro
    I'm not too familiar with Windows scripts - but does it proceed better if you remove the 'call' before executing acusim.bat?
    User: "acupro"
    Altair Employee
    Updated by acupro
    Did it proceed better if you remove the 'call' before executing acusim.bat?
    User: "FrankSu"
    OP
    Updated by FrankSu
    I tried, it's the same.
    User: "acupro"
    Altair Employee
    Updated by acupro
    It seems the last line of the acusim.bat script opens a command-prompt, and for some reason commands do not proceed after that.
    Let's assume you're going to execute the .bat file from another command-prompt, and not by double-clicking the .bat file itself.  You can copy the relevant items from acusim.bat into your own .bat file - but at the start of that, you'll probably need to hard-set the initial directories.
    If you're using version 2020 in the default location, try putting the following ahead of your first cd operation.  (The formatting may be strange here - so you may want to copy directly from acusim.bat, then make the appropriate changes to match the lines below.)  Note I've added @ECHO OFF and then later ECHO so those commands don't get 'echoed' into the command prompt.  The main things you'll need to hardcode are ACUSIM_HOME and ACUSIM_MACHINE.
    title ACUSOLVE
    @ECHO OFF
    rem -------------------------------------------------------------------------
    rem Set home and machine
    set ACUSIM_HOME=C:\Program Files\Altair\2020\hwcfdsolvers\acusolve
    set ACUSIM_MACHINE=win64
    set ACUSIM_VERSION=.
    rem Add %SystemRoot%\system32 path if it does not exist
    set findPath="%SYSTEMROOT%\System32\find.exe"
    set PATH=%PATH:"=%
    echo %PATH% | %findPath% "%SystemRoot%\system32" > nul
    if "%errorlevel%" neq "0" (
    if defined PATH (
    set "PATH=%SystemRoot%\system32;%PATH%"
    ) else (
    set PATH=%SystemRoot%\system32;
    rem Set environment variables
    set PATH=%ACUSIM_HOME%\%ACUSIM_MACHINE%\perl\bin;%PATH%
    set ACUSIM_ROOT=%ACUSIM_HOME%\%ACUSIM_MACHINE%
    set ACUSIM_SYSTEM_CNF=%ACUSIM_ROOT%\script\Acusim.cnf
    if "%ACUSIM_CNF_FILES%" == "" (
    set ACUSIM_CNF_FILES=.\Acusim.cnf:%USERPROFILE%\Acusim.cnf:%ACUSIM_SYSTEM_CNF%
    set PATH=%ACUSIM_ROOT%\abaqus-odb\lib;%PATH%
    set PATH=%ACUSIM_ROOT%\base\lib\site-packages;%PATH%
    set PATH=%ACUSIM_ROOT%\base\DLLs;%PATH%
    set PATH=%ACUSIM_ROOT%\bin;%PATH%
    set PATH=%ACUSIM_ROOT%\..\..\..\mpi\%ACUSIM_MACHINE%\mpich\bin;%PATH%
    set P_SCHEMA=%ACUSIM_ROOT%\script\schema
    if "%ALTAIR_LICENSE_PATH%" == "" (
    set "ALTAIR_LICENSE_PATH=%ACUSIM_HOME%\..\..\security\altair_lic.dat"
    ) else (
    set "ALTAIR_LICENSE_PATH=%ALTAIR_LICENSE_PATH%;%ACUSIM_HOME%\..\..\security\altair_lic.dat"
    set RADFLEX_PATH=%ACUSIM_ROOT%\bin
    ECHO
