not found mpich2mpi.dll
Hello everyone,
When I use AcuSolve Job Launcher 2020, my job can run normally,
but now I have two jobs to run continuous, I use a batch file to execute,
here is my batch file content:
CD D:\Analysis\run_xxx1
call "C:\Program Files\Altair\2020\hwcfdsolvers\acusolve\win64\bin\acuRun.bat" -pb xxx1 -inp xxx1.inp -np 4
CD D:\Analysis\run_xxx2
call "C:\Program Files\Altair\2020\hwcfdsolvers\acusolve\win64\bin\acuRun.bat" -pb xxx2 -inp xxx2.inp -np 4
when I execute this batch, the system will comes out a warning message "not found mpich2mpi.dll"
Dose anyone know how to fix it? please.
Thank you
Thanks a lot, @acupro
I used the 2nd method, and it works.
But as a side note, I tried to increase 1st row to execute acusim.bat in my batch file, like following
call "C:\Program Files\Altair\2020\hwcfdsolvers\acusolve\win64\bin\acusim.bat"
CD \Analysis\run_xxx1
CD \Analysis\run_xxx2
then I executed the batch file,
the Command Prompt seems stop while it after executing first row, like the image below.
CD
\Analysis\run_xxx1
CD\Analysis\run_xxx2
call "C:\Program Files\Altair\2020\hwcfdsolvers\acusolve\win64\bin\acuRun.bat" -pb xxx2 -inp xxx2.inp -np 4-----------------
I'm not too familiar with Windows scripts - but does it proceed better if you remove the 'call' before executing acusim.bat?
CD
\Analysis\run_xxx1
Did it proceed better if you remove the 'call' before executing acusim.bat?
I tried, it's the same.
It seems the last line of the acusim.bat script opens a command-prompt, and for some reason commands do not proceed after that.
Let's assume you're going to execute the .bat file from another command-prompt, and not by double-clicking the .bat file itself. You can copy the relevant items from acusim.bat into your own .bat file - but at the start of that, you'll probably need to hard-set the initial directories.
If you're using version 2020 in the default location, try putting the following ahead of your first cd operation. (The formatting may be strange here - so you may want to copy directly from acusim.bat, then make the appropriate changes to match the lines below.) Note I've added @ECHO OFF and then later ECHO so those commands don't get 'echoed' into the command prompt. The main things you'll need to hardcode are ACUSIM_HOME and ACUSIM_MACHINE.
title ACUSOLVE
@ECHO OFF
rem -------------------------------------------------------------------------
rem Set home and machine
set ACUSIM_HOME=C:\Program Files\Altair\2020\hwcfdsolvers\acusolve
set ACUSIM_MACHINE=win64
set ACUSIM_VERSION=.
rem Add %SystemRoot%\system32 path if it does not exist
set findPath="%SYSTEMROOT%\System32\find.exe"
set PATH=%PATH:"=%
echo %PATH% | %findPath% "%SystemRoot%\system32" > nul
if "%errorlevel%" neq "0" (
if defined PATH (
set "PATH=%SystemRoot%\system32;%PATH%"
) else (
set PATH=%SystemRoot%\system32;
rem Set environment variables
set PATH=%ACUSIM_HOME%\%ACUSIM_MACHINE%\perl\bin;%PATH%
set ACUSIM_ROOT=%ACUSIM_HOME%\%ACUSIM_MACHINE%
set ACUSIM_SYSTEM_CNF=%ACUSIM_ROOT%\script\Acusim.cnf
if "%ACUSIM_CNF_FILES%" == "" (
set ACUSIM_CNF_FILES=.\Acusim.cnf:%USERPROFILE%\Acusim.cnf:%ACUSIM_SYSTEM_CNF%
set PATH=%ACUSIM_ROOT%\abaqus-odb\lib;%PATH%
set PATH=%ACUSIM_ROOT%\base\lib\site-packages;%PATH%
set PATH=%ACUSIM_ROOT%\base\DLLs;%PATH%
set PATH=%ACUSIM_ROOT%\bin;%PATH%
set PATH=%ACUSIM_ROOT%\..\..\..\mpi\%ACUSIM_MACHINE%\mpich\bin;%PATH%
set P_SCHEMA=%ACUSIM_ROOT%\script\schema
if "%ALTAIR_LICENSE_PATH%" == "" (
set "ALTAIR_LICENSE_PATH=%ACUSIM_HOME%\..\..\security\altair_lic.dat"
) else (
set "ALTAIR_LICENSE_PATH=%ALTAIR_LICENSE_PATH%;%ACUSIM_HOME%\..\..\security\altair_lic.dat"
set RADFLEX_PATH=%ACUSIM_ROOT%\bin
ECHO
My first thought is that you issuing this from a command prompt that does not have the AcuSolve environment established. You have two choices:
1. Issue this from the AcuSolve Command Prompt - which should appear under Altair 2020 from the Windows Start menu.
or
2. From any Command Prompt first run the script to establish the AcuSolve environment.
"C:\Program Files\Altair\2020\hwcfdsolvers\acusolve\win64"\bin\acusim.bat
or the equivalent as you type out that path - maybe the quotes will be slightly different.
In either case, before you launch your run script, make sure your command prompt 'knows' acuRun, by trying:
acuRun -h
This will tell you whether or not the environment is established correctly. Once that is confirmed, you can modify your script to:
cd
\Analysis\run_xxx1
\Analysis\run_xxx2
call acuRun -pb xxx1 -inp xxx1.inp -np 4
cd
call acuRun -pb xxx2 -inp xxx2.inp -np 4
As a side note, Altair Simulation 2021 has now been released, so you could update to the latest version. The same process will still apply.
