Generate OP2 file
Hi, All:
May I ask how can I generate .op2 file in my OptiStruct analysis?
Thank you very much for your help.
Hi
in panel analysis>control card
you activate card named OUTPUT then select its keyword as OP2
Hi, Tinh:
Thank you very much for your help. Every time when I got a question, you replied me very quickly. I got a follow up question about moving things in AcuSolve. If I need to move the red block to the place of the grey box, and to make sure the left-bottom points are at the same location after moving. May I ask if there is a way to do it? Just like moving blocks in AutoCAD using reference points.
Thank you.
Hi
Hi, Tinh:
i got it. I can use 'position' to do it. Thank you.
Can you read op2 by python? HW already integrated python.
Sample:
https://pynastran-git.readthedocs.io/en/latest/quick_start/op2_demo.html
Sample:
I guess that the setup.py generates the compiled function test_op2. Where I can find it 'setup.py' ?
Hi
Hello, i did that, but it didnt generate any .op2 file, do you have any idea what i could have done wrong?
The hm file is attached below
Thank you in advance
This thread is 5yrs old!
I ran your model, with no modifications at all to your set up, and got op2 (attached)
Hi
