Generate OP2 file
User: "Altair Forum User"
Altair Employee
Updated by Altair Forum User
Hi, All:
May I ask how can I generate .op2 file in my OptiStruct analysis?
Thank you very much for your help.
1 - 12 of 121
    User: "tinh"
    Altair Community Member
    Updated by tinh
    Hi
    in panel analysis>control card
    you activate card named OUTPUT then select  its keyword as OP2
    Altair Employee
    OP
    Hi
    Hi, Tinh:
    Thank you very much for your help. Every time when I got a question, you replied me very quickly. I got a follow up question about moving things in AcuSolve. If I need to move the red block to the place of the grey box, and to make sure the left-bottom points are at the same location after moving. May I ask if there is a way to do it? Just like moving blocks in AutoCAD using reference points.
    Thank you.
    Altair Employee
    OP
    Hi
    Hi, Tinh:
    i got it. I can use 'position' to do it. Thank you.
    User: "FaroukM"
    Updated by FaroukM
    Hi
    Do you have any solution to export op2 file to an ASCII file ?
    Thanks,
    User: "tinh"
    Updated by tinh
    I am not sure but if you can open op2 by hyperview then you could export that data to text format
    User: "FaroukM"
    Updated by FaroukM
    I can't open *k.op2 or *m.op2 file with hyperview ? Did you try it before ?
    User: "tinh"
    Updated by tinh
    Can you read op2 by python? HW already integrated python.
    Sample:
    https://pynastran-git.readthedocs.io/en/latest/quick_start/op2_demo.html
    User: "FaroukM"
    Updated by FaroukM
    Sample:
    I guess that the setup.py generates the compiled function test_op2. Where I can find it 'setup.py' ?
    User: "tinh"
    Updated by tinh
    Hi
    I think google can find it.
    Are you sure hyperview can't open op2? It's strange.
    User: "FaroukM"
    Updated by FaroukM
    I will have a look
    I tried but I can't open it ! It's a *k.op2 file ...
    User: "Arthur Rocha_20936"
    Updated by Arthur Rocha_20936
    Hi
    Hello, i did that, but it didnt generate any .op2 file, do you have any idea what i could have done wrong?
    The hm file is attached below
    Thank you in advance
    User: "PaulAltair"
    Altair Employee
    Updated by PaulAltair
    This thread is 5yrs old!
    I ran your model, with no modifications at all to your set up, and got op2 (attached)
