Error 1000
Hello,
I have to do simulation and optimisation of a Sandwich structure with carbon fibre laminate face sheets and aluminium honeycomb core. In Simulation a 3 point bednding test as well as a shear Test has to be conducted and I have following problems regarding it.
1) Solid-Shell Connection: I read in one the replies on this forum that in order to get the connection between solid(core) and shell(laminate plies)it is good to generate faces on solid through Tools->Faces and give the faces a property of PSHELL with a Thickness of .001. I have done the same and wanted to check if the model is correct so applied some random value of force on the uppermost laminate. Unfortunately I m getting an error „Error 1000*** in the input data:incorrect data in the field#3.” Could you please tell me how to remove it, secondly it i have Modelled it correct.
Thanks
With Regards
Abhinav
Hallo Prakash,
I tried creating a new element like you advised with drag. I did get the element created however it creates two elements. I have given the settings as -2.5mm distance, drag 1. Even after equivalence it doesnt work. I am still having an unwanted elemnt, even if i try to delete , it deletes both the elements since it takes it as a whole one element
With Regards
Abhinav
Hi Abhinav,
You can delete the elements and create single elements using create element (F6) just by selecting surrounding nodes.
Hallo Prakash,
that didn't work for me either. I cannot select the nodes on the ply. When I create these elements they are not on the desired ply.
i have sent two times sinces its shows session expired again and again.
apart from that, is it possible to check the energy absorbed by the structure?( internal energy )
I have downloaded it, but it didn´t somehow solve the issue, which I wanted.
If you try on some ply from the top laminat lets say PLYS_104101, it doesnt work out.
Abhinav,
Please check the normals.
If the normals are fine, I would suggest you to update the elements for plies.
Hello,
I am Hardik and i am getting error like ' ERROR # 1000 *** in the input data:
Incorrect data in field # 3' this and Too many error messages. Aborting run.
Current limit is 10000. Use 'MSGLMT' control card to change this value.
what should i do.
Hello Rahul,
i already send you d .fem file.did you receive that or not?
Hello Rahul,
It was my mistake and i send you again the .hm file.Please check it out.
Thank you,
Regards,
Hardik
Hello,
I am getting some problem regarding assigning property to mesh.I don't understand how can i assign property to mesh because i have three different material with that three different property and i tried with all this three property but then i am getting error 78.So i don't understand which property i will assign and with which material
Thank you
Hardik
Hi Abhinav,
Go to 2D panel and you can use Drag nodes/elements to create elements, but make sure you do this in glass fiber component.
Manufacturing ply thickness is ignored in freesize and whatever PLYMAN/TAMNF you provide will be carried to size optimization phase.
You can provide different manufacturing ply thickness by editing the PLY>> TMANUF>>VALUE
