Error 1000
2»
Answers
  • Altair Forum User
    Altair Forum User
    Altair Employee
    edited December 2017
    Hi Abhinav,
    Go to 2D panel and you can use Drag nodes/elements to create elements, but make sure you do this in glass fiber component.
    Manufacturing ply thickness is ignored in freesize and whatever PLYMAN/TAMNF you provide will be carried to size optimization phase.
    You can provide different manufacturing ply thickness by editing the PLY>> TMANUF>>VALUE
  • Altair Forum User
    Altair Forum User
    Altair Employee
    Hallo Prakash,
    I tried creating a new element like you advised with drag. I did get the element created however it creates two elements. I have given the settings as -2.5mm distance, drag 1. Even after equivalence it doesnt work. I am still having an unwanted elemnt, even if i try to delete , it deletes both the elements since it takes it as a whole one element
    With Regards
    Abhinav
  • Altair Forum User
    Altair Forum User
    Altair Employee
    Hi Abhinav,
    You can delete the elements and create single elements using create element (F6) just by selecting surrounding nodes.
  • Altair Forum User
    Altair Forum User
    Altair Employee
    Hallo Prakash,
    that didn't work for me either. I cannot select the nodes on the ply. When I create these elements they are not on the desired ply.
  • Altair Forum User
    Altair Forum User
    Altair Employee
    Hi Abhinav,
    Can you share the model file, please?
  • Altair Forum User
    Altair Forum User
    Altair Employee
    did you receive it?
  • Altair Forum User
    Altair Forum User
    Altair Employee
    i have sent two times sinces its shows session expired again and again.
  • Altair Forum User
    Altair Forum User
    Altair Employee
    apart from that, is it possible to check the energy absorbed by the structure?( internal energy )
  • Altair Forum User
    Altair Forum User
    Altair Employee
  • Altair Forum User
    Altair Forum User
    Altair Employee
    Hi @Abhinav
    PFA
    Let me know when you are done,  I will remove the file from the post
  • Altair Forum User
    Altair Forum User
    Altair Employee
    I have downloaded it, but it didn´t somehow solve the issue, which I wanted.
    If you try on some ply from the top laminat lets say PLYS_104101, it doesnt work out.
  • Altair Forum User
    Altair Forum User
    Altair Employee
    Abhinav,
    Please check the normals.
    If the normals are fine, I would suggest you to update the elements for plies.
  • Altair Forum User
    Altair Forum User
    Altair Employee
    edited November 2020
    Hello,
    I am Hardik and i am getting error like '  ERROR # 1000 *** in the input data:
     Incorrect data in field # 3' this  and Too many error messages. Aborting run.
     Current limit is 10000. Use 'MSGLMT' control card to change this value.
    what should i do.
  • Rahul Rajan_21763
    Rahul Rajan_21763 New Altair Community Member
    edited June 2018
    Hi Hardik,
    Please share .fem file?
  • Altair Forum User
    Altair Forum User
    Altair Employee
    edited June 2018
    Hello Rahul,
    i already send you d .fem file.did you receive that or not?
  • tinh
    tinh Altair Community Member
    edited June 2018
    What you should do is assign property for the tetra component
    please check other component also.
  • Altair Forum User
    Altair Forum User
    Altair Employee
    edited June 2018
    Hello Rahul,
     It was my mistake and i send you again the .hm file.Please check it out.
    Thank you,
    Regards,
    Hardik
  • Altair Forum User
    Altair Forum User
    Altair Employee
    edited June 2018
    Hello tinh,
    I did not assign property to tetra and when i assign psolid then also its shows error
  • Altair Forum User
    Altair Forum User
    Altair Employee
    edited June 2018
    Hello,
     I am getting some problem regarding assigning property to mesh.I don't understand how can i assign property to mesh because i have three different material with that three different property and i tried with all this three property but then i am getting error 78.So i don't understand which property i will assign and with which material
    Thank you
    Hardik
  • tinh
    edited June 2018
    maybe you assigned 'PLSOLID' while it should be 'PSOLID'
    please refer to
Welcome!
Welcome!
