Altair RISE
Nominate Yourself Now!
Error 1000
User: "Altair Forum User"
Altair Employee
Updated by Altair Forum User
Hello,
I have to do simulation and optimisation of a Sandwich structure with carbon fibre laminate face sheets and aluminium honeycomb core. In Simulation a 3 point bednding test as well as a shear Test has to be conducted and I have following problems regarding it.
1) Solid-Shell Connection: I  read in one the replies on this  forum that in order to get the connection between solid(core) and shell(laminate plies)it is good to generate faces on solid through Tools->Faces and give the faces a property of PSHELL with a Thickness of .001. I have done the same and wanted to check if the model is correct so applied some random value of force on the uppermost laminate. Unfortunately I m getting an error „Error 1000*** in the input data:incorrect data in the field#3.” Could you please tell me how to remove it, secondly it i have Modelled  it correct.
Thanks
With Regards
Abhinav
31 - 50 of 502
    Altair Employee
    OP
    Hi Abhinav,
    Go to 2D panel and you can use Drag nodes/elements to create elements, but make sure you do this in glass fiber component.
    Manufacturing ply thickness is ignored in freesize and whatever PLYMAN/TAMNF you provide will be carried to size optimization phase.
    You can provide different manufacturing ply thickness by editing the PLY>> TMANUF>>VALUE
    Altair Employee
    OP
    Hallo Prakash,
    I tried creating a new element like you advised with drag. I did get the element created however it creates two elements. I have given the settings as -2.5mm distance, drag 1. Even after equivalence it doesnt work. I am still having an unwanted elemnt, even if i try to delete , it deletes both the elements since it takes it as a whole one element
    With Regards
    Abhinav
    Altair Employee
    OP
    Hi Abhinav,
    You can delete the elements and create single elements using create element (F6) just by selecting surrounding nodes.
    Altair Employee
    OP
    Hallo Prakash,
    that didn't work for me either. I cannot select the nodes on the ply. When I create these elements they are not on the desired ply.
    Altair Employee
    OP
    Hi Abhinav,
    Can you share the model file, please?
    Altair Employee
    OP
    did you receive it?
    Altair Employee
    OP
    i have sent two times sinces its shows session expired again and again.
    Altair Employee
    OP
    apart from that, is it possible to check the energy absorbed by the structure?( internal energy )
    Altair Employee
    OP
    Altair Employee
    OP
    Hi @Abhinav
    PFA
    Let me know when you are done,  I will remove the file from the post
    Altair Employee
    OP
    I have downloaded it, but it didn´t somehow solve the issue, which I wanted.
    If you try on some ply from the top laminat lets say PLYS_104101, it doesnt work out.
    Altair Employee
    OP
    Abhinav,
    Please check the normals.
    If the normals are fine, I would suggest you to update the elements for plies.
    Altair Employee
    OP
    Hello,
    I am Hardik and i am getting error like '  ERROR # 1000 *** in the input data:
     Incorrect data in field # 3' this  and Too many error messages. Aborting run.
     Current limit is 10000. Use 'MSGLMT' control card to change this value.
    what should i do.
    User: "Rahul Rajan_21763"
    New Altair Community Member
    Updated by Rahul Rajan_21763
    Hi Hardik,
    Please share .fem file?
    Altair Employee
    OP
    Hello Rahul,
    i already send you d .fem file.did you receive that or not?
    User: "tinh"
    Updated by tinh
    What you should do is assign property for the tetra component
    please check other component also.
    Altair Employee
    OP
    Hello Rahul,
     It was my mistake and i send you again the .hm file.Please check it out.
    Thank you,
    Regards,
    Hardik
    Altair Employee
    OP
    Hello tinh,
    I did not assign property to tetra and when i assign psolid then also its shows error
    Altair Employee
    OP
    Hello,
     I am getting some problem regarding assigning property to mesh.I don't understand how can i assign property to mesh because i have three different material with that three different property and i tried with all this three property but then i am getting error 78.So i don't understand which property i will assign and with which material
    Thank you
    Hardik
    User: "tinh"
    Updated by tinh
    maybe you assigned 'PLSOLID' while it should be 'PSOLID'
    please refer to
31 - 50 of 502
