Altair RISE
Nominate Yourself Now!
Doubts Reg. Application of two or more Loads in Single Load Case
User: "Gowtham2022"
Altair Community Member
Hi Experts,
I am using Optistruct to solve the structural problems.
I case of Two Wheeler Disc Brake Rotor Structural Simulation two or more Loads (Imposed Displacement of Brake Pads, Clamping forces and Torque) will act at same time . Is it possible to give two or more loads in Single Load Case or can we combine the Different Loads.
If it possible to perform such type of Load case in Optistruct can you please suggest the procedure to execute the simulation.
For such instance some of sample tutorial images from different solvers had been attached below for your reference.
1 - 6 of 61
