Doubts Reg. Application of two or more Loads in Single Load Case
Hi Experts,
I am using Optistruct to solve the structural problems.
I case of Two Wheeler Disc Brake Rotor Structural Simulation two or more Loads (Imposed Displacement of Brake Pads, Clamping forces and Torque) will act at same time . Is it possible to give two or more loads in Single Load Case or can we combine the Different Loads.
If it possible to perform such type of Load case in Optistruct can you please suggest the procedure to execute the simulation.
For such instance some of sample tutorial images from different solvers had been attached below for your reference.
Hi Solon,
I have tried to solve the simulation as per our discussions and references even though my simulation is not converging. Can you please correct my simulation procedure or specify my mistake. So, I could rectify the issue.
If Possible could you please share your mail id.
I have attached some of the image and OUT file for your reference. Kindly find the attachments.
Kindly please note that I am sovling the simaultion in Implict method.
Please take a look at this good article for Troubleshooting for OptiStruct Nonlinear Convergence Issues.
It seems that the contacts are apart at the start of the analysis causing singularity. Ensure that the contacts are initially touching, and/or add contact stabilization energy via CNTSTB bulk data entry:
Hello,
you can refer to the first part of the following tutorial:
https://help.altair.com/hwsolvers/os/topics/solvers/os/simlab_brake_squeal_analysis_tutorial_intro_r.htm
In general you can add multiple loads with a LOADADD bulk data entry:
https://help.altair.com/hwsolvers/os/topics/solvers/os/loadadd_bulk_r.htm?zoom_highlight=loadadd
