Baja Car Frame Analysis using SimSolid Solver in Inspire
By Koushik Chandrashekhar
I am going to pariticipate in SAEINDIA Baja 2026 competition, we are really stuck where to start from with CAE we kindly request an altair team any supporting tutorials or training vedios related to Baja with New version of Altair interface would be help ful to us to understand better and perform simulations using Altair software for our Baja rollcage
Types of Analysis:
Linear static analysis
Crash analysis
CFD
MBD(Mutli body dynamics)
Thanks
Megha sai
Hi @Meghasai_1828,
If you are new to HyperMesh, then you should look into the eLearning modules available for this product:
Getting Started with HyperMesh v2024:
Altair HyperMesh for Pre-Post Processing v2024:
If you look into the first link I provided, you can see there is a section already devoted to the roll cage assessment. A similar approach can be taken using HyperMesh:
Hope this helps!
Adam Reid
Hi @Meghasai_1828,
There are many Discussion posts already dedicated to this topic. Please find them at the following links, or just search for BAJA in the search bar:
Also, please complete many of the eLearning modules at the following link:
Hope this helps!
Adam Reid
Hi @GTT Adam
Good morning,
Thank you for your response to my previous query. However, we are still facing challenges at the point where we begin the process. Let's assume we are using a CAD software to complete our modeling, and once we import a STEP or IGES file into HyperMesh 2025, we are unsure about the next steps. We are currently stuck at this stage in terms of the entire procedure—preprocessing, solving, and postprocessing.
I would greatly appreciate it if you could provide us with a detailed, step-by-step procedure for completing the simulation of a Baja SAE rollcage using HyperMesh 2025. Your guidance would be incredibly helpful in navigating through the process.
Thank you for your time and assistance
Hi @Meghasai_1828,
Hope this helps!
Adam Reid
