EDEM API: Particle Body Force - Particle Growth Cycle
Overview
This API allows you to simulate any kind of particle expansion/growth/swelling and shrinkage in EDEM. There is also an example attached that shows the usage of the API.
Usage/Installation Instructions
- Extract the zip file attached. Copy the 'ParticleGrowthCycle.dll' and 'ParticleGrowthCycleInput.txt' from the 'example' folder to the directory of your EDEM simulation.
- Add the plugin model in 'Particle Body Force' of the Physics section.
- You must enter three different values - expansion/shrinkage rate, final scale and start time of the expansion/shrinkage, in the preference file (ParticleGrowthCycleInput.txt).
Use negative values for shrinkage. Higher the rate, faster the process. - You can have multiple lines of the values to indicate different cycles of swelling and shrinkage in your simulation. Note that you can have a maximum of 40 rows only.
All the particles in your simulation will grow/shrink at the rate you specify in the preference file.
Post-Requisite
If you are interested in just the expansion/shrinkage once, and not necessarily the cycle of expansion/shrinkage, you can refer to this API: https://community.altair.com/community/en/edem-api-particle-body-force-particle-growth?id=kb_article&sysparm_article=KB0122138
You will also be able to add different rates for different particles using the linked API.
- As the particle size and volume increase, the particle mass also increases proportionally with respect to its volume. However, it can also be useful to keep the particle mass constant even as the size grows. To achieve this, is it possible to reduce the density of each particle at every time step? In recent EDEM 2025.1 release note, the Mass Scaling Factor seems to do the trick.
- I use the input file ParticleGrowthCycleInput.txt to assign all the rates for particles A, B, and C, followed by their final scales. Logically, the program should read the rates and final scales in the order of the particle names; however, this is not happening.
- For ex., if I have the input file as
- A B C
- 10 30 50 1.10 1.30 1.50
- Then, I have another input file
- C B A
- 50 30 10 1.50 1.30 1.10
- These two files should produce the same results, but they don't. It appears that the API determines the particle order solely based on the sequence shown in EDEM Analyst under Particles, rather than the order in the input file. I think this issue is solely on my end due to bug.
- Lastly, I realized that the growth rate is applied geometrically, where the scale at each time step is calculated using:
scale = (1 + rate × timestep) ^ number of timesteps.
However, a more intuitive approach might be to apply a linear increase using:
scale = original particle scale × (1 + rate × timestep × number of timesteps)
However, I don't know if original particle scale can be accessed anywhere. - You are correct, you can set the mass scaling factor using setMassScale() and getMassScale() function available inside the class IParticleManagerApi_1_8 from the 2025.1 version.
- This API sets all the particles growth rate simultaneously, and does not give an option to set rates for individual particles. If you are interested in setting rates for individual particles, please check this API:
Hi Jerrinjobs
I have tried using Altair 2024.1 but the error still occurred.
I download the file and open it, without any modification or changing the file location. But the error still occur.
May I know what I should do? I googled my problem, and one post mentioned that I need to recompile the plugin.
Hi,
Recompiling often would work, as it may not be loading if you don't have the required pre-requisites on your computer and installing visual studio and compiling resolves this. You can also just install the pre-requsities e.g.
It could also be file permissions, you will need to have read/write/execute permissions for the folder containing the .dll.
Regards
Stephen
Hi, this is a great API code that it worked well for examples and my dem simulation. I would like to know how to add different rates for different particles. This was not explicitly stated in the link provided which is about "particle growth". I looked at both codes and tried to modify "ECalculateResult CParticleGrowthCycle::externalForce". However, the particles remain unchanged.
Hi @TonyC I'd recommend watching the intro to EDEM API YouTube series:
It would be under the externalForce function in CParticleGrowthCycle.cpp (for CPU) and PartilceGrowthCycle.cu (for GPU).
You need to search out a particle type by name (particle.type) and apply the apply the code to this type only.
We have an example for Geometries where we only remove particles contacting a specifically named geometry:
Regards
Stephen
Dear @Stephen Cole , Thank you very much for your detailed reply.
I watched all the YouTube videos and read the removing particles example. However, I am still unsuccessful in editing API codes. The wheel button found in the removing particles example is not accessble in the particle growth cycle dll. It is still unclear what you mean by "You need to search out a particle type by name (particle.type) and apply the apply the code to this type only." Would you please elaborate how this can be done in the API code? Is particle.type command only available in the gpu file (cu) or also available in cpu? I really appreciate your help.
Best,
Tony Cho
Hi Tony,
There are also the EDEM API tutorials which would be helpful go to through:
You can input data to an API model via a Text File or user input via the user interface. You have to code this in if you want to use something like the wheel to add an input. There is a guide here:
https://help.altair.com/edem/topics/coupling_interface_programming_guide/api_gui_guide_c.htm
However that's not where I would start out, I would recommend just coding the name in directly. In the particle removal example there is the code:
// Get the geometry name as a string
const std::string geometry_name = GEOM_NAME.getString();
// Check if the particle is in contact with the geometry
if (strcmp(element2.type, geometry_name.c_str()) == 0)
//update mass passed custom prop with the mass of the particle removed
double* massPassedDelta = elem2CustomProperties->getDelta(iMASSPASSED);
massPassedDelta[0] += element1.mass;
//remove particle
m_particleMngr->markForRemoval(element1.ID);
This checks if element2.type (the geometry) has the same name as user defined geometry_name string, and if so then removes the particle.
If you wanted to apply different growth rates to different particles, or similar you would want code more like:
const std::string name1 = "particle1";
const std::string name2 = "particle2"; if (strcmp(element1.type, name1.c_str()) == 0)
{ //apply growth rate for particles called "particle1" here } else if(strcmp(element1.type, name2.c_str()) == 0)
{ //apply growth rate for particles called "particle2" here }
note that element1 is always a particle, element2 can be particle or geometry so should also check for name of element2 if it's a Contact Model. If using a Body Force its "particle.type" not "elementn.type"
The above code example if for CPU which is always a good place to start coding as it's easier to debug, if you are using shapes that run on CPU like Spheres, polyhedral particles run on GPU only but you could still run a CPU sphere test case.
Regards
Stephen
Dear @Stephen Cole, thank you very much for your support. I got cpu code working finally. I tried to get cuda working as well, but strcmp or the standard library doesn't seem to work in cuda. In cuda, should I use assign index (integer) for each particle instead of element1.type (string) for this line?
I really appreciate your support always!
Hi,
As you say GPU CUDA code doesn't allow for strings, so we have to use the CPU to convert our particle name to an integer ID. THen pass the ID from CPU to GPU and in the GPU code use the integer to check. It is a bit of an involved process but this code does the same:
On the CPU we have:
unsigned int CRemoveParticles::getGeometryParameterData(const char geometryType[], void* parameterData)
double* params = reinterpret_cast<double*>(parameterData);
std::string temp = geometryType;
std::string geometryName = GEOM_NAME.getString();
if (strcmp(temp.c_str(), geometryName.c_str()) == 0)
params[0] = 1;
else
params[0] = 0;
return sizeof(double);
Which is comparing the geometryType[] with the geometryName string (which we want to pass to GPU). If it is the name we want were assigning it value 1.
Then in the GPU CUDA code we have:
real geometry = CUtilitiesPrecision::convertToReal(*(double*)(element2.getParameterData()));
if (geometry == REAL_CONST(1.0))
customPropReal* massPassedDelta = element2.getCustomPropertyDelta(MASS_PASSED_INDEX);
massPassedDelta[0] += CUtilitiesPrecision::convertToCustomPropReal(element1.getMass());
//remove the particle
element1.markForRemoval();
Using getParameterData for element2 (element2 is particle or geometry, element1 is always particle) we find the parameter and write it to 'geometry'. Then if geometry is 1.0 we know its the specifically named geometry that we identified by string on the CPU and can process this.
The previously mentioned EDEM API: Particle Body Force – Particle Growth post does already use the getParticleParemeterData function to pass info to the GPU so you can extend this to more than 1 parameter. Example code that uses more than 1 parameter can be seen here:
Dear @Stephen Cole,
I have been using this API and would appreciate it if you could answer some additional questions I have.
I really appreciate your help always! I can't thank you enough for your support.
Warm regards,
Tony Cho
Hi TonyC
Glad to hear that you have been using this API.
3. This current version of the API assumes an exponential growth rate. Please feel free to modify it according to your needs related to the growth rate. You can find the original particle scale in line 119 of the original code.
const double* particleOriginalScale = particleCustomProperties→getValue(iORIGINAL_SCALE);
Thanks,
Jerrin Job
Hi
When I opened the example this error showed up:
WARNING : Plugin : Could not load plugin file:
D:/ParticleGrowthCycle/example\ParticleGrowthCycle.dll
May I know what I should do to solve this problem?
