Overview
This API allows you to simulate any kind of particle expansion/growth/swelling and shrinkage in EDEM. There is also an example attached that shows the usage of the API.
- Extract the zip file attached. Copy the 'ParticleGrowthCycle.dll' and 'ParticleGrowthCycleInput.txt' from the 'example' folder to the directory of your EDEM simulation.
- Add the plugin model in 'Particle Body Force' of the Physics section.
- You must enter three different values - expansion/shrinkage rate, final scale and start time of the expansion/shrinkage, in the preference file (ParticleGrowthCycleInput.txt).
Use negative values for shrinkage. Higher the rate, faster the process. - You can have multiple lines of the values to indicate different cycles of swelling and shrinkage in your simulation. Note that you can have a maximum of 40 rows only.
All the particles in your simulation will grow/shrink at the rate you specify in the preference file.
Post-Requisite
If you are interested in just the expansion/shrinkage once, and not necessarily the cycle of expansion/shrinkage, you can refer to this API: https://community.altair.com/community/en/edem-api-particle-body-force-particle-growth?id=kb_article&sysparm_article=KB0122138
You will also be able to add different rates for different particles using the linked API.
