Have you been able to run any of the tutorial models - or is this your first attempt to run a CFD/AcuSolve model from SimLab?
Look in the 'Fluids and Particle Dynamics' section.
Which SimLab version are you using?
For the standard/commercial installation, along with the SimLab installer itself, the SimLab Additionals zip file needs to be in the same directory as the SimLab installer, when that installer is run. I'm assuming it's the same for the student version - but not positive on that. If you did not have the SimLab Additionals zip file when you installed SimLab, you'll need to uninstall SimLab, download the zip file into the same directory as the installer - then install SimLab agina.
Just to make sure you did the reinstall correctly:
Uninstall SimLab completely.
Place your previously downloaded SimLab installer ( AltairSimLab2024.1_win64.exe ) into a directory. Also place your previously downloaded Additionals zip file ( SimLab2024.1_Additionals_Windows.zip ) into that same directory with the .exe file. *** NOTE - your filenames/versions will likely be different - but similar.
Double-click the SimLab installer ( AltairSimLab2024.1_win64.exe ) to install SimLab. The installer will make use of the zip file during the installation.
Is that the process you already followed? If you're still not running, does it help to decrease the Number of Processors from 8 to 2 or 1 in the 'Format and Execute Options' pop-up?
It could be a licensing issue - I think you mentioned student licensing. Did you do the reinstall with the same SimLab version you had working before? You can have multiple versions installed - so maybe try the same installation process (.exe and .zip in same directory) with the same release version you had earlier (provided you first uninstall that particular version)
Under your Solution - right-click 'Settings' and select 'Format and Execute Options'. Is there something there that looks incorrect? Feel free to add the snapshot showing that pop-up.
