Export Example set and Performance Vector
Hi guys,
as part of my sentiment analysis I am receiving results in the "Results" tab, which are named "PerformanceVector (Performance)" and "ExampleSet (Apply Model(2)).
I want to export them into an Excel file exactly as shown in the two pictures below, so exactly the way they are in the Results tab.
But when I e.g. use the Write Excel operator behind apply model, the columns "prediction" both "confidence" columns and the "text" column are gone and I need them in my exported file. The results are then like this:
Have you guys got any solution for that issue?
Cheers!
Cheers!
