Error reading Excel files - issue probably due to merged cells in first row
Hello eveverybody,
I am simply trying to import data from Excel files.
Unfortunately, I am facing an issue using the read Excel function as shown in the next picture :
I notice that this is most probably due to the fact that cell 1A is merge with cell B1.
Indeed, when I try my process using "Unmerged.xlsx" file, it works while when I try my process using "Merge.xlsx" file, it fails.
Could you please help me to solve this issue ?
The example of the process and example files are available in attachment.
Best regards
Hervé
1 - 5 of
51
Either you can skip that row entirely (and just add your attribute names after manually if needed), or you can unmerge the cells prior to reading it in.
Dear Telcontar120,
Thank you for your reply. I have tried to skip this row using imported cell range parameter (value of A2:B4 for example) but I still got the error message. Is there another way to skip lines in Excel files ?
Is there a way to unmerge cells in RapidMiner process ?
Best regards
Hervé
Dear Telcontar120,
Thank you for your reply. Could you please let me known how to use annotations parameter to skip rows ?
Best regards
Hervé
