Change unix time stamp on loop
Hi - i have spent a lot of time searching the forum, but cant work it out.
Wondering if anyone can help me please. I am trying to loop using a macro and changing a value that is inserted in to the URL (a different UNIX timestamp) on each iteration,.
I want to do this in order to loop sucessive calls to the API to get more history data as per call it is limited to 2000 records (hours in this case).
So I would like to get a longer history in order to try some predictions on it.
I have worked out how to get the last value of the UNIX time stamp from the first run, and then use that in a loop as the starting point for a second run and merge both sets of data to one file to get 4000 hours.
The problem is I cant work out how to loop gain and change the value for a more sucessive times each loop. to get more history.
- The data is hour based ticker price, from cryptocompare limited to 2000 hours per call,
It is posible to insert the value from the earliest UNIX time stamp date from the first run to complete sucessive runs to get earlier data.
&limit=2000&toTs={the earliest timestamp received}
https://min-api.cryptocompare.com/data/histohour?fsym=%{fsym}&tsym=%{tsym}&limit=%{limit}&toTs=%{toTs}&api_key={api_key}
Process attached
(i have removed my API) you can get one free to test it. from here https://min-api.cryptocompare.com/documentation?key=Historical&cat=dataHistohour
Any help appreciated - thanks, Lee
Process attached
1 - 6 of
61
How about you generate the macro "toTS" inside the loop again by subtracting the time as a function of iteration index.
Hi @hbajpai, thanks for your reply. Im a novice, been struggling with this for 2 days
Would it be possible to send me an example or screenshot of how to set up subtracting the time as function of iteration index, or modifing the processs file attached to my question as described? it would be greatly appreciated. Regards Lee
Hi @websiteguy
You should use the Generate Macro operator. With this you can update the macro's value by evaluating the previous value.
Best,
Sebastian
Best,
Sebastian
Hi @SGolbert - thanks for reply
pointed me in the right direction Generate macro was the Key. After some more exsperementing got it working where it loops through and collects data.
Had to change the name of the second macro generated after the first loop to myMacro1 and use that value in toTs in the loop.
Very happy to have sorted it out - thanks for your advice. happy to have spent two days trying to work it out and then sucess
BOOM
Hello, I am pulling in submission through a form on our website and it is all formatted in UNIX/UTC date time - that's what I found out by googling this issue, but I haven't found a workable solution to convert UNIX/UTC time code to user readable date and time stamp (01/01/2016 01:00:00 PM) etc. Please help thank you
Hi!
It is possible to convert into both directions.
Unix timestamp (large number) to date: Use the Numerical to Date operator. It operates on milliseconds, classic Unix timestamp is in seconds. So if you get values around 1970, just multiply the number with 1000 to get the actual datetime.
Date/time to Unix (Java) timestamp: Use Generate Attributes with the date_millis() function, or Date to Numerical with the "relative to" setting set to the epoch.
Regards,
Balázs
Regards,
Balázs
1 - 1 of
11
Hi @websiteguy
Best,
Sebastian
Best,
Sebastian
