Aylien extension : input attribute
Hi,
I just want to try a simple process to see if Aylien extension works well, so I just use two operators, Read Excel and Analyze Sentiment. I'm sure I set correct API key and API id, but in the parameter, I can't see any options like those I saw in tutorial, like "Text", "Language", etc. And when I manually type Text in this option and run this process, the operator Read Excel runs well, but Analyze Sentiment is a little weird, it doesn't seem to contain any error but it can't run. Can anyone help me to see what I did wrong in this process ?
Otherwise, I noticed that for Analyze Sentiment, input should be ExampleSet, so can we just import one single excel using Read Excel like this ? Or type something using Create Document ?
Thanks in advance.
LL
Thanks in advance.
LL
1 - 1 of
11
Aylien is no longer supporting their extension for RapidMiner, so it is going to be tough to get help if you are running into problems with it. I suggest trying one of the other API text mining extensions that has a built in sentiment analyzer like Rosette or MonkeyLearn, or even the new RapidMiner native operator for this (called Extract Sentiment, which you need to install from the free Operator Toolbox extension).
