Updating Anaconda and Tensorflow breaks the execute Python extension.
New Altair Community Member
Updated by Jocelyn
Just updated my Tensorflow env which was working fine in Rapidminer before I did my conda update tensorflow 20 minutes ago. I am surprised that updating Anaconda would do this.
I am running in to problems everyday with 9.2.
1 - 6 of
61
- Install Anaconda.
- Create an environment solely for RapidMiner:
$ conda create --name=rapidminer python=3.7 - Activate the environment for RapidMiner:
$ conda activate rapidminer - Install pandas for the new environment:
$ conda install pandas - List the environments I have:
$ conda env list - Copy the path of the environment I created, add /bin/python to the end and use that path to configure the Python extension.
- Deactivate the environment:
$ conda deactivate - base
- rapidminer
- servers
- selenium
- fileparsing
- datamining
- webapps
- daemons
- project***
hughesfleming68
OPUpdated by hughesfleming68
I solved the problem by downgrading Python to 3.6.5. The question is.....what is happening? Obviously, not upgrading Anaconda can only last so long as a workaround. Is there anything on the Anaconda side that needs to be done?
Hi @hughesfleming68,
I'm running on 3.7.2 without problems.
When you install a new Python distribution with conda update, you create a bare one as if you would have installed Miniconda. The problem isn't solved by downgrading but by installing Pandas on the new version after upgrading.
What I normally do:
Hope this helps,
Rodrigo.
What I normally do:
Hope this helps,
Rodrigo.
The idea behind anaconda is to have different environments per project or kind of project at least. I do have this separation:
All the best,
Rodrigo.
All the best,
Rodrigo.
Thank you Rodrigo. I understand the benefits of different environments. I already had Rapidminer working in a custom tensorflow env. It is unfortunate that the solution is to create a new env and basically set everything up again because a tensorflow update broke the connection with Rapidminer.
regards,
Alex
regards,
Alex
1 - 1 of
11
- Install Anaconda.
$ conda deactivate
What I normally do:
Hope this helps,
Rodrigo.
What I normally do:
Hope this helps,
Rodrigo.
