Altair RISE
Nominate Yourself Now!
Radoop Read Database - Out of Memory
User: "JEdward"
New Altair Community Member
Updated by Jocelyn
Hi guys,
I'm running a Radoop Read Database operator inside a Radoop Nest, but when executing on RM Server (small) it runs out of memory.
My understanding of that operator is that it streams data directly into Hive and so shouldn't run out of memory.
Is this a bug?
1 - 7 of 71
    User: "JEdward"
    OP
    To assist if anyone is able, here is a sample log file.
    Basic gist is:
    After some gubbins Radoop begins to execute the query.
    2 mins later the memory usage on Server begins to rise.
    4 later the memory runs out and an OOM flag is created
    4 mins later the process halts due to an OOM error.
    The table size is 14GB and appears to run without any significant memory rise on my local laptop.  It is only on the Server where memory usage does this.  (Bit awkward when wanting to execute it overnight) -- EDIT:  mistake on my side. This is also occuring on the laptop too, but is much slower as it takes longer to run the query and begin fetching all rows into memory. --
    Other tables have so far been much smaller.  One table was a large size (5 GB), and trigged an OOM flag on the server execution, but still managed to continue and successfully stream the data despite this.  It is just this 14GB table that is causing issues.
    2018-07-23 15:30:57.266  INFO 23995 --- [main] c.r.execution.jobcontainer.Application   : Starting Application on centos with PID 23995 (/xxxxxxxx/job-agent/engine/rapidminer-jobcontainer-0.2.3.jar started by root in /)
    2018-07-23 15:30:57.269 INFO 23995 --- [main] c.r.execution.jobcontainer.Application : No active profile set, falling back to default profiles: default
    2018-07-23 15:30:57.574 INFO 23995 --- [main] s.c.a.AnnotationConfigApplicationContext : Refreshing org.springframework.context.annotation.AnnotationConfigApplicationContext@62379589: startup date [Mon Jul 23 15:30:57 CST 2018]; root of context hierarchy
    2018-07-23 15:30:58.706 INFO 23995 --- [main] o.s.s.c.ThreadPoolTaskScheduler : Initializing ExecutorService 'taskScheduler'
    2018-07-23 15:30:59.425 INFO 23995 --- [main] o.s.j.e.a.AnnotationMBeanExporter : Registering beans for JMX exposure on startup
    2018-07-23 15:30:59.433 INFO 23995 --- [main] o.s.c.support.DefaultLifecycleProcessor : Starting beans in phase 0
    2018-07-23 15:30:59.520 INFO 23995 --- [taskScheduler-1] c.r.e.j.service.RemoteRepositoryService : Trying to update JWT token from auth properties.
    2018-07-23 15:30:59.520 INFO 23995 --- [taskScheduler-2] c.r.e.j.service.OutOfMemoryWatchdog : Checking memory usage of Job Container
    2018-07-23 15:30:59.521 INFO 23995 --- [taskScheduler-1] c.r.e.j.service.RemoteRepositoryService : Updated JWT token from auth properties file.
    2018-07-23 15:30:59.521 INFO 23995 --- [taskScheduler-2] c.r.e.j.service.OutOfMemoryWatchdog : Current memory usage is 544MB / 16384MB
    2018-07-23 15:30:59.523 INFO 23995 --- [main] c.r.e.j.s.RapidMinerInitializerService : Changing 'user.home' system property to 'xxxxxxxx/job-agent/jobs/41468b0b-725e-4d51-9fcd-9cb04929d056'
    2018-07-23 15:30:59.524 INFO 23995 --- [main] c.r.e.j.s.RapidMinerInitializerService : Generating new in-memory cipher key
    2018-07-23 15:30:59.555 INFO 23995 --- [main] c.r.e.j.s.RapidMinerInitializerService : Loading JDBC properties
    2018-07-23 15:30:59.746 INFO 23995 --- [main] c.r.e.j.s.RapidMinerInitializerService : Setting pre-defined system properties for Job Container
    2018-07-23 15:30:59.747 INFO 23995 --- [main] c.r.e.j.s.RapidMinerInitializerService : Initializing the RapidMiner Core
    2018-07-23 15:30:59.747 INFO 23995 --- [main] c.r.e.j.s.RapidMinerInitializerService : Setting execution mode to 'APPSERVER'
    2018-07-23 15:30:59.747 INFO 23995 --- [main] c.r.e.j.s.RapidMinerInitializerService : Loading extensions from 'xxxxxxxxxx/.rapidminer/extensions'
    2018-07-23 15:30:59.757 INFO 23995 --- [main] com.rapidminer : Performing upgrade to version 8.1.000
    2018-07-23 15:30:59.758 INFO 23995 --- [main] com.rapidminer : Set locale to en.
    2018-07-23 15:30:59.830 INFO 23995 --- [main] PlatformUtilities : rapidminer.home is 'xxxxxxxxxxx/job-agent/engine'.
    2018-07-23 15:30:59.853 INFO 23995 --- [main] com.rapidminer : Initializing license manager.
    2018-07-23 15:30:59.960 INFO 23995 --- [main] com.rapidminer : Cannot access file system in execution mode APPSERVER. Not loading repositories.
    2018-07-23 15:31:00.162 INFO 23995 --- [main] com.rapidminer : Register plugin: PMML
    2018-07-23 15:31:00.162 INFO 23995 --- [main] com.rapidminer : Register plugin: JDBC Connectors
    2018-07-23 15:31:00.162 INFO 23995 --- [main] com.rapidminer : Register plugin: Remote Repository
    2018-07-23 15:31:00.162 INFO 23995 --- [main] com.rapidminer : Register plugin: Advanced File Connectors
    2018-07-23 15:31:00.162 INFO 23995 --- [main] com.rapidminer : Register plugin: Professional
    2018-07-23 15:31:00.163 INFO 23995 --- [main] com.rapidminer : Register plugin: Productivity
    2018-07-23 15:31:00.163 INFO 23995 --- [main] com.rapidminer : Register plugin: Legacy Result Access
    2018-07-23 15:31:00.163 INFO 23995 --- [main] com.rapidminer : Register plugin: Process Scheduling
    2018-07-23 15:31:00.163 INFO 23995 --- [main] com.rapidminer : Register plugin: Social Media
    2018-07-23 15:31:00.163 INFO 23995 --- [main] com.rapidminer : Register plugin: Cloud Connectivity
    2018-07-23 15:31:00.163 INFO 23995 --- [main] com.rapidminer : Register plugin: H2O
    2018-07-23 15:31:00.163 INFO 23995 --- [main] com.rapidminer : Register plugin: Concurrency
    2018-07-23 15:31:00.163 INFO 23995 --- [main] com.rapidminer : Register plugin: Model Simulator
    2018-07-23 15:31:00.987 INFO 23995 --- [main] com.rapidminer : Register plugin: Advanced Reporting Extension
    2018-07-23 15:31:00.988 INFO 23995 --- [main] com.rapidminer : Register plugin: Converters
    2018-07-23 15:31:00.988 INFO 23995 --- [main] com.rapidminer : Register plugin: Google Cloud Platform
    2018-07-23 15:31:00.988 INFO 23995 --- [main] com.rapidminer : Register plugin: Hive Connector
    2018-07-23 15:31:00.988 INFO 23995 --- [main] com.rapidminer : Register plugin: Model Management
    2018-07-23 15:31:00.988 INFO 23995 --- [main] com.rapidminer : Register plugin: MonkeyLearn
    2018-07-23 15:31:00.988 INFO 23995 --- [main] com.rapidminer : Register plugin: NamSor
    2018-07-23 15:31:00.989 INFO 23995 --- [main] com.rapidminer : Register plugin: NoSQL
    2018-07-23 15:31:00.989 INFO 23995 --- [main] com.rapidminer : Register plugin: Pdf Table Extraction
    2018-07-23 15:31:00.989 INFO 23995 --- [main] com.rapidminer : Register plugin: Qlik Connector
    2018-07-23 15:31:00.989 INFO 23995 --- [main] com.rapidminer : Register plugin: QuantX-1 Extension
    2018-07-23 15:31:00.989 INFO 23995 --- [main] com.rapidminer : Register plugin: RapidProM
    2018-07-23 15:31:00.990 INFO 23995 --- [main] com.rapidminer : Register plugin: Reporting
    2018-07-23 15:31:00.990 INFO 23995 --- [main] com.rapidminer : Register plugin: Rosette Text Analytics
    2018-07-23 15:31:00.990 INFO 23995 --- [main] com.rapidminer : Register plugin: SAS Connector
    2018-07-23 15:31:00.990 INFO 23995 --- [main] com.rapidminer : Register plugin: semweb
    2018-07-23 15:31:00.990 INFO 23995 --- [main] com.rapidminer : Register plugin: Value Series
    2018-07-23 15:31:00.990 INFO 23995 --- [main] com.rapidminer : Register plugin: SharePoint Connector
    2018-07-23 15:31:00.990 INFO 23995 --- [main] com.rapidminer : Register plugin: Solr
    2018-07-23 15:31:00.991 INFO 23995 --- [main] com.rapidminer : Register plugin: Splunk
    2018-07-23 15:31:00.991 INFO 23995 --- [main] com.rapidminer : Register plugin: Spreadsheet Table Extraction
    2018-07-23 15:31:00.991 INFO 23995 --- [main] com.rapidminer : Register plugin: Statistics Extension
    2018-07-23 15:31:00.991 INFO 23995 --- [main] com.rapidminer : Register plugin: Tableau Table Writer
    2018-07-23 15:31:00.991 INFO 23995 --- [main] com.rapidminer : Register plugin: Text Processing
    2018-07-23 15:31:00.991 INFO 23995 --- [main] com.rapidminer : Register plugin: Timeseries
    2018-07-23 15:31:00.992 INFO 23995 --- [main] com.rapidminer : Register plugin: Web Mining
    2018-07-23 15:31:00.992 INFO 23995 --- [main] com.rapidminer : Register plugin: Weka
    2018-07-23 15:31:00.992 INFO 23995 --- [main] com.rapidminer : Register plugin: Word2Vec
    2018-07-23 15:31:00.992 INFO 23995 --- [main] com.rapidminer : Register plugin: Keras
    2018-07-23 15:31:00.992 INFO 23995 --- [main] com.rapidminer : Register plugin: Python Scripting
    2018-07-23 15:31:00.992 INFO 23995 --- [main] com.rapidminer : Register plugin: R Scripting
    2018-07-23 15:31:00.993 INFO 23995 --- [main] com.rapidminer : Register plugin: Operator Toolbox
    2018-07-23 15:31:00.993 INFO 23995 --- [main] com.rapidminer : Register plugin: Web Table Extraction
    2018-07-23 15:31:00.993 INFO 23995 --- [main] com.rapidminer : Register plugin: Radoop
    2018-07-23 15:31:03.024 INFO 23995 --- [main] com.rapidminer : Registered configurator MonkeyLearn API Key.
    2018-07-23 15:31:04.523 INFO 23995 --- [taskScheduler-1] c.r.e.j.service.OutOfMemoryWatchdog : Checking memory usage of Job Container
    2018-07-23 15:31:04.523 INFO 23995 --- [taskScheduler-1] c.r.e.j.service.OutOfMemoryWatchdog : Current memory usage is 4352MB / 16384MB
    2018-07-23 15:31:09.525 INFO 23995 --- [taskScheduler-2] c.r.e.j.service.OutOfMemoryWatchdog : Checking memory usage of Job Container
    2018-07-23 15:31:09.525 INFO 23995 --- [taskScheduler-2] c.r.e.j.service.OutOfMemoryWatchdog : Current memory usage is 6784MB / 16384MB
    2018-07-23 15:31:14.526 INFO 23995 --- [taskScheduler-2] c.r.e.j.service.OutOfMemoryWatchdog : Checking memory usage of Job Container
    2018-07-23 15:31:14.526 INFO 23995 --- [taskScheduler-2] c.r.e.j.service.OutOfMemoryWatchdog : Current memory usage is 6784MB / 16384MB
    2018-07-23 15:31:19.526 INFO 23995 --- [taskScheduler-2] c.r.e.j.service.OutOfMemoryWatchdog : Checking memory usage of Job Container
    2018-07-23 15:31:19.527 INFO 23995 --- [taskScheduler-2] c.r.e.j.service.OutOfMemoryWatchdog : Current memory usage is 6784MB / 16384MB
    2018-07-23 15:31:21.868 INFO 23995 --- [main] com.rapidminer : Registered configurator Rosette Connection.
    2018-07-23 15:31:22.004 INFO 23995 --- [main] com.rapidminer : Registered configurator Twitter Connection.
    2018-07-23 15:31:22.136 INFO 23995 --- [main] com.rapidminer : Registered configurator Splunk.
    2018-07-23 15:31:22.882 INFO 23995 --- [main] com.rapidminer : Registered configurator Salesforce Connection.
    2018-07-23 15:31:22.882 INFO 23995 --- [main] com.rapidminer : Registered configurator Amazon S3 Connection.
    2018-07-23 15:31:22.882 INFO 23995 --- [main] com.rapidminer : Registered configurator Azure Blob Storage Connection.
    2018-07-23 15:31:22.883 INFO 23995 --- [main] com.rapidminer : Registered configurator Dropbox Connection.
    2018-07-23 15:31:23.763 INFO 23995 --- [main] com.rapidminer : Registered configurator Hive Connection.
    2018-07-23 15:31:24.050 WARN 23995 --- [main] com.rapidminer : Missing database driver class name for ODBC Bridge (e.g. Access)
    2018-07-23 15:31:24.051 WARN 23995 --- [main] com.rapidminer : Missing database driver class name for Ingres
    2018-07-23 15:31:24.528 INFO 23995 --- [taskScheduler-2] c.r.e.j.service.OutOfMemoryWatchdog : Checking memory usage of Job Container
    2018-07-23 15:31:24.528 INFO 23995 --- [taskScheduler-2] c.r.e.j.service.OutOfMemoryWatchdog : Current memory usage is 6784MB / 16384MB
    2018-07-23 15:31:24.589 INFO 23995 --- [main] com.rapidminer : Registered configurator Cassandra Connection.
    2018-07-23 15:31:24.589 INFO 23995 --- [main] com.rapidminer : Registered configurator MongoDB Connection.
    2018-07-23 15:31:24.625 INFO 23995 --- [main] com.rapidminer : Registered configurator SFTP Connection.
    2018-07-23 15:31:25.064 INFO 23995 --- [main] com.rapidminer : Registered configurator Solr Connection.
    2018-07-23 15:31:25.604 INFO 23995 --- [main] com.rapidminer : Registered configurator Radoop Proxy Connection.
    2018-07-23 15:31:25.638 INFO 23995 --- [main] com.rapidminer : Radoop temp dir is /tmp/radoop_b75332_2062335884213589671
    2018-07-23 15:31:26.128 INFO 23995 --- [main] com.rapidminer : Registered configurator Radoop Proxy Connection.
    2018-07-23 15:31:26.171 INFO 23995 --- [main] com.rapidminer : Radoop temp dir is /tmp/radoop_b41848_2801983644937285609
    2018-07-23 15:31:27.099 INFO 23995 --- [main] com.rapidminer : Extension QuantX-1 Extension was loaded in 2ms.
    2018-07-23 15:31:27.099 INFO 23995 --- [main] com.rapidminer : Extension Model Management was loaded in 2ms.
    2018-07-23 15:31:27.100 INFO 23995 --- [main] com.rapidminer : Extension semweb was loaded in 2ms.
    2018-07-23 15:31:27.100 INFO 23995 --- [main] com.rapidminer : Extension Pdf Table Extraction was loaded in 2ms.
    2018-07-23 15:31:27.100 INFO 23995 --- [main] com.rapidminer : Extension Google Cloud Platform was loaded in 4ms.
    2018-07-23 15:31:27.100 INFO 23995 --- [main] com.rapidminer : Extension Web Table Extraction was loaded in 4ms.
    2018-07-23 15:31:27.100 INFO 23995 --- [main] com.rapidminer : Extension Timeseries was loaded in 5ms.
    2018-07-23 15:31:27.100 INFO 23995 --- [main] com.rapidminer : Extension Reporting was loaded in 5ms.
    2018-07-23 15:31:27.100 INFO 23995 --- [main] com.rapidminer : Extension PMML was loaded in 5ms.
    2018-07-23 15:31:27.100 INFO 23995 --- [main] com.rapidminer : Extension SharePoint Connector was loaded in 5ms.
    2018-07-23 15:31:27.101 INFO 23995 --- [main] com.rapidminer : Extension Converters was loaded in 6ms.
    2018-07-23 15:31:27.101 INFO 23995 --- [main] com.rapidminer : Extension SAS Connector was loaded in 8ms.
    2018-07-23 15:31:27.101 INFO 23995 --- [main] com.rapidminer : Extension Statistics Extension was loaded in 8ms.
    2018-07-23 15:31:27.101 INFO 23995 --- [main] com.rapidminer : Extension Value Series was loaded in 9ms.
    2018-07-23 15:31:27.101 INFO 23995 --- [main] com.rapidminer : Extension MonkeyLearn was loaded in 11ms.
    2018-07-23 15:31:27.101 INFO 23995 --- [main] com.rapidminer : Extension Keras was loaded in 13ms.
    2018-07-23 15:31:27.101 INFO 23995 --- [main] com.rapidminer : Extension Advanced Reporting Extension was loaded in 35ms.
    2018-07-23 15:31:27.102 INFO 23995 --- [main] com.rapidminer : Extension Weka was loaded in 38ms.
    2018-07-23 15:31:27.102 INFO 23995 --- [main] com.rapidminer : Extension Spreadsheet Table Extraction was loaded in 47ms.
    2018-07-23 15:31:27.102 INFO 23995 --- [main] com.rapidminer : Extension Text Processing was loaded in 58ms.
    2018-07-23 15:31:27.102 INFO 23995 --- [main] com.rapidminer : Extension Operator Toolbox was loaded in 79ms.
    2018-07-23 15:31:27.102 INFO 23995 --- [main] com.rapidminer : Extension NamSor was loaded in 87ms.
    2018-07-23 15:31:27.102 INFO 23995 --- [main] com.rapidminer : Extension Word2Vec was loaded in 121ms.
    2018-07-23 15:31:27.102 INFO 23995 --- [main] com.rapidminer : Extension Tableau Table Writer was loaded in 132ms.
    2018-07-23 15:31:27.103 INFO 23995 --- [main] com.rapidminer : Extension Splunk was loaded in 139ms.
    2018-07-23 15:31:27.103 INFO 23995 --- [main] com.rapidminer : Extension Concurrency was loaded in 140ms.
    2018-07-23 15:31:27.103 INFO 23995 --- [main] com.rapidminer : Extension Productivity was loaded in 144ms.
    2018-07-23 15:31:27.103 INFO 23995 --- [main] com.rapidminer : Extension Model Simulator was loaded in 144ms.
    2018-07-23 15:31:27.103 INFO 23995 --- [main] com.rapidminer : Extension R Scripting was loaded in 145ms.
    2018-07-23 15:31:27.103 INFO 23995 --- [main] com.rapidminer : Extension Python Scripting was loaded in 147ms.
    2018-07-23 15:31:27.103 INFO 23995 --- [main] com.rapidminer : Extension Qlik Connector was loaded in 147ms.
    2018-07-23 15:31:27.103 INFO 23995 --- [main] com.rapidminer : Extension Legacy Result Access was loaded in 149ms.
    2018-07-23 15:31:27.104 INFO 23995 --- [main] com.rapidminer : Extension Remote Repository was loaded in 150ms.
    2018-07-23 15:31:27.104 INFO 23995 --- [main] com.rapidminer : Extension Advanced File Connectors was loaded in 150ms.
    2018-07-23 15:31:27.104 INFO 23995 --- [main] com.rapidminer : Extension Professional was loaded in 151ms.
    2018-07-23 15:31:27.104 INFO 23995 --- [main] com.rapidminer : Extension Rosette Text Analytics was loaded in 154ms.
    2018-07-23 15:31:27.104 INFO 23995 --- [main] com.rapidminer : Extension Process Scheduling was loaded in 159ms.
    2018-07-23 15:31:27.104 INFO 23995 --- [main] com.rapidminer : Extension Solr was loaded in 177ms.
    2018-07-23 15:31:27.104 INFO 23995 --- [main] com.rapidminer : Extension Social Media was loaded in 183ms.
    2018-07-23 15:31:27.104 INFO 23995 --- [main] com.rapidminer : Extension NoSQL was loaded in 279ms.
    2018-07-23 15:31:27.104 INFO 23995 --- [main] com.rapidminer : Extension Cloud Connectivity was loaded in 282ms.
    2018-07-23 15:31:27.105 INFO 23995 --- [main] com.rapidminer : Extension JDBC Connectors was loaded in 334ms.
    2018-07-23 15:31:27.105 INFO 23995 --- [main] com.rapidminer : Extension Web Mining was loaded in 364ms.
    2018-07-23 15:31:27.105 INFO 23995 --- [main] com.rapidminer : Extension H2O was loaded in 373ms.
    2018-07-23 15:31:27.105 INFO 23995 --- [main] com.rapidminer : Extension Hive Connector was loaded in 794ms.
    2018-07-23 15:31:27.105 INFO 23995 --- [main] com.rapidminer : Extension Radoop was loaded in 1851ms.
    2018-07-23 15:31:27.105 WARN 23995 --- [main] com.rapidminer : Extension RapidProM was loaded in 18 s.
    2018-07-23 15:31:29.560 INFO 23995 --- [taskScheduler-2] c.r.e.j.service.OutOfMemoryWatchdog : Checking memory usage of Job Container
    2018-07-23 15:31:29.561 INFO 23995 --- [taskScheduler-2] c.r.e.j.service.OutOfMemoryWatchdog : Current memory usage is 6784MB / 16384MB
    2018-07-23 15:31:31.628 WARN 23995 --- [main] com.rapidminer : Malformed operoator documentation: com.rapidminer.tools.XMLException: Missing tag: <name> in <operator>.
    at com.rapidminer.io.process.XMLTools.getTagContents(XMLTools.java:379)
    at com.rapidminer.tools.documentation.XMLOperatorDocBundle.<init>(XMLOperatorDocBundle.java:153)
    at com.rapidminer.tools.documentation.XMLOperatorDocBundle$XMLControl.newBundle(XMLOperatorDocBundle.java:102)
    at java.util.ResourceBundle.loadBundle(ResourceBundle.java:1510)
    at java.util.ResourceBundle.findBundle(ResourceBundle.java:1474)
    at java.util.ResourceBundle.findBundle(ResourceBundle.java:1428)
    at java.util.ResourceBundle.getBundleImpl(ResourceBundle.java:1370)
    at java.util.ResourceBundle.getBundle(ResourceBundle.java:1308)
    at com.rapidminer.tools.documentation.XMLOperatorDocBundle.load(XMLOperatorDocBundle.java:187)
    at com.rapidminer.tools.OperatorService.parseOperators(OperatorService.java:310)
    at com.rapidminer.tools.OperatorService.registerOperators(OperatorService.java:273)
    at com.rapidminer.tools.plugin.Plugin.registerOperators(Plugin.java:632)
    at com.rapidminer.tools.plugin.Plugin.registerAllPluginOperators(Plugin.java:1033)
    at com.rapidminer.tools.OperatorService.init(OperatorService.java:180)
    at com.rapidminer.RapidMiner.init(RapidMiner.java:741)
    at com.rapidminer.execution.jobcontainer.service.RapidMinerInitializerService.initializeCore(RapidMinerInitializerService.java:100)
    at com.rapidminer.execution.jobcontainer.service.RapidMinerInitializerService.initializeAll(RapidMinerInitializerService.java:48)
    at com.rapidminer.execution.jobcontainer.EngineRunner.onApplicationEvent(EngineRunner.java:54)
    at com.rapidminer.execution.jobcontainer.EngineRunner.onApplicationEvent(EngineRunner.java:30)
    at org.springframework.context.event.SimpleApplicationEventMulticaster.invokeListener(SimpleApplicationEventMulticaster.java:167)
    at org.springframework.context.event.SimpleApplicationEventMulticaster.multicastEvent(SimpleApplicationEventMulticaster.java:139)
    at org.springframework.context.support.AbstractApplicationContext.publishEvent(AbstractApplicationContext.java:393)
    at org.springframework.context.support.AbstractApplicationContext.publishEvent(AbstractApplicationContext.java:347)
    at org.springframework.boot.context.event.EventPublishingRunListener.finished(EventPublishingRunListener.java:101)
    at org.springframework.boot.SpringApplicationRunListeners.callFinishedListener(SpringApplicationRunListeners.java:79)
    at org.springframework.boot.SpringApplicationRunListeners.finished(SpringApplicationRunListeners.java:72)
    at org.springframework.boot.SpringApplication.run(SpringApplication.java:305)
    at com.rapidminer.execution.jobcontainer.Application.main(Application.java:43)
    2018-07-23 15:31:31.629 WARN 23995 --- [main] com.rapidminer : Malformed operoator documentation: com.rapidminer.tools.XMLException: Missing tag: <name> in <operator>.
    2018-07-23 15:31:31.646 WARN 23995 --- [main] n.s.ehcache.config.ConfigurationFactory : No configuration found. Configuring ehcache from ehcache-failsafe.xml found in the classpath: jar:file:xxxxxxxxxx/.rapidminer/extensions/rmx_namsor-6.5.12.jar!/ehcache-failsafe.xml
    2018-07-23 15:31:32.446 WARN 23995 --- [main] com.rapidminer : PCA number of fixed result components was set to 2. Operator can only reduce to 0
    2018-07-23 15:31:34.561 INFO 23995 --- [taskScheduler-2] c.r.e.j.service.OutOfMemoryWatchdog : Checking memory usage of Job Container
    2018-07-23 15:31:34.562 INFO 23995 --- [taskScheduler-2] c.r.e.j.service.OutOfMemoryWatchdog : Current memory usage is 6784MB / 16384MB
    2018-07-23 15:31:37.581 INFO 23995 --- [main] com.rapidminer : Cannot access file system in execution mode APPSERVER. Not loading repositories.
    2018-07-23 15:31:37.593 INFO 23995 --- [main] com.rapidminer : Load configuration for MonkeyLearn API Key.
    2018-07-23 15:31:37.594 INFO 23995 --- [main] com.rapidminer : No configuration file found for MonkeyLearn API Key
    2018-07-23 15:31:37.594 INFO 23995 --- [main] com.rapidminer : Loaded configurations for 0 objects of type MonkeyLearn API Key.
    2018-07-23 15:31:37.594 INFO 23995 --- [main] com.rapidminer : Load configuration for Rosette Connection.
    2018-07-23 15:31:37.594 INFO 23995 --- [main] com.rapidminer : No configuration file found for Rosette Connection
    2018-07-23 15:31:37.595 INFO 23995 --- [main] com.rapidminer : Loaded configurations for 0 objects of type Rosette Connection.
    2018-07-23 15:31:37.595 INFO 23995 --- [main] com.rapidminer : Load configuration for SFTP Connection.
    2018-07-23 15:31:37.595 INFO 23995 --- [main] com.rapidminer : No configuration file found for SFTP Connection
    2018-07-23 15:31:37.595 INFO 23995 --- [main] com.rapidminer : Loaded configurations for 0 objects of type SFTP Connection.
    2018-07-23 15:31:37.595 INFO 23995 --- [main] com.rapidminer : Load configuration for Cassandra Connection.
    2018-07-23 15:31:37.595 INFO 23995 --- [main] com.rapidminer : No configuration file found for Cassandra Connection
    2018-07-23 15:31:37.595 INFO 23995 --- [main] com.rapidminer : Loaded configurations for 0 objects of type Cassandra Connection.
    2018-07-23 15:31:37.595 INFO 23995 --- [main] com.rapidminer : Load configuration for Amazon S3 Connection.
    2018-07-23 15:31:37.595 INFO 23995 --- [main] com.rapidminer : No configuration file found for Amazon S3 Connection
    2018-07-23 15:31:37.595 INFO 23995 --- [main] com.rapidminer : Loaded configurations for 0 objects of type Amazon S3 Connection.
    2018-07-23 15:31:37.596 INFO 23995 --- [main] com.rapidminer : Load configuration for Azure Blob Storage Connection.
    2018-07-23 15:31:37.596 INFO 23995 --- [main] com.rapidminer : No configuration file found for Azure Blob Storage Connection
    2018-07-23 15:31:37.596 INFO 23995 --- [main] com.rapidminer : Loaded configurations for 0 objects of type Azure Blob Storage Connection.
    2018-07-23 15:31:37.596 INFO 23995 --- [main] com.rapidminer : Load configuration for Dropbox Connection.
    2018-07-23 15:31:37.596 INFO 23995 --- [main] com.rapidminer : No configuration file found for Dropbox Connection
    2018-07-23 15:31:37.596 INFO 23995 --- [main] com.rapidminer : Loaded configurations for 0 objects of type Dropbox Connection.
    2018-07-23 15:31:37.596 INFO 23995 --- [main] com.rapidminer : Load configuration for Salesforce Connection.
    2018-07-23 15:31:37.596 INFO 23995 --- [main] com.rapidminer : No configuration file found for Salesforce Connection
    2018-07-23 15:31:37.596 INFO 23995 --- [main] com.rapidminer : Loaded configurations for 0 objects of type Salesforce Connection.
    2018-07-23 15:31:37.596 INFO 23995 --- [main] com.rapidminer : Load configuration for Hive Connection.
    2018-07-23 15:31:37.596 INFO 23995 --- [main] com.rapidminer : No configuration file found for Hive Connection
    2018-07-23 15:31:37.597 INFO 23995 --- [main] com.rapidminer : Loaded configurations for 0 objects of type Hive Connection.
    2018-07-23 15:31:37.597 INFO 23995 --- [main] com.rapidminer : Load configuration for MongoDB Connection.
    2018-07-23 15:31:37.597 INFO 23995 --- [main] com.rapidminer : No configuration file found for MongoDB Connection
    2018-07-23 15:31:37.597 INFO 23995 --- [main] com.rapidminer : Loaded configurations for 0 objects of type MongoDB Connection.
    2018-07-23 15:31:37.597 INFO 23995 --- [main] com.rapidminer : Load configuration for Radoop Proxy Connection.
    2018-07-23 15:31:37.597 INFO 23995 --- [main] com.rapidminer : No configuration file found for Radoop Proxy Connection
    2018-07-23 15:31:37.597 INFO 23995 --- [main] com.rapidminer : Loaded configurations for 0 objects of type Radoop Proxy Connection.
    2018-07-23 15:31:37.597 INFO 23995 --- [main] com.rapidminer : Load configuration for Solr Connection.
    2018-07-23 15:31:37.597 INFO 23995 --- [main] com.rapidminer : No configuration file found for Solr Connection
    2018-07-23 15:31:37.597 INFO 23995 --- [main] com.rapidminer : Loaded configurations for 0 objects of type Solr Connection.
    2018-07-23 15:31:37.598 INFO 23995 --- [main] com.rapidminer : Load configuration for Splunk.
    2018-07-23 15:31:37.598 INFO 23995 --- [main] com.rapidminer : No configuration file found for Splunk
    2018-07-23 15:31:37.598 INFO 23995 --- [main] com.rapidminer : Loaded configurations for 0 objects of type Splunk.
    2018-07-23 15:31:37.598 INFO 23995 --- [main] com.rapidminer : Load configuration for Twitter Connection.
    2018-07-23 15:31:37.598 INFO 23995 --- [main] com.rapidminer : No configuration file found for Twitter Connection
    2018-07-23 15:31:37.598 INFO 23995 --- [main] com.rapidminer : Loaded configurations for 0 objects of type Twitter Connection.
    2018-07-23 15:31:37.600 INFO 23995 --- [main] c.r.e.j.s.RapidMinerInitializerService : License framework initialized. Current active license edition is 'small'. The license expires on '2018-11-27'.
    2018-07-23 15:31:37.600 INFO 23995 --- [main] c.r.execution.jobcontainer.EngineRunner : Starting execution of process with job ID '41468b0b-725e-4d51-9fcd-9cb04929d056' for user 'john'.
    2018-07-23 15:31:37.600 INFO 23995 --- [main] c.r.e.j.service.RemoteRepositoryService : Executed process is stored in 'xxxxxxxxxx/RADOOP - 0_ import tables from RDS'.
    2018-07-23 15:31:37.603 INFO 23995 --- [main] c.r.e.j.service.RemoteRepositoryService : Trying to update JWT token from auth properties.
    2018-07-23 15:31:37.603 INFO 23995 --- [main] c.r.e.j.service.RemoteRepositoryService : Skipped updating the JWT token as old one equals the new one.
    2018-07-23 15:31:37.603 INFO 23995 --- [main] c.r.e.j.service.RemoteRepositoryService : Initializing the connection to RapidMiner Server. Using protocol 'http', host '0.0.0.0', and port '8088'
    2018-07-23 15:31:37.620 INFO 23995 --- [main] com.rapidminer : Loading 0 configurations of type MonkeyLearn API Key from RapidMiner Server _LOCAL
    2018-07-23 15:31:37.623 INFO 23995 --- [main] com.rapidminer : Loading 0 configurations of type Rosette Connection from RapidMiner Server _LOCAL
    2018-07-23 15:31:37.626 INFO 23995 --- [main] com.rapidminer : Loading 0 configurations of type SFTP Connection from RapidMiner Server _LOCAL
    2018-07-23 15:31:37.629 INFO 23995 --- [main] com.rapidminer : Loading 0 configurations of type Cassandra Connection from RapidMiner Server _LOCAL
    2018-07-23 15:31:37.631 INFO 23995 --- [main] com.rapidminer : Loading 0 configurations of type Amazon S3 Connection from RapidMiner Server _LOCAL
    2018-07-23 15:31:37.634 INFO 23995 --- [main] com.rapidminer : Loading 0 configurations of type Azure Blob Storage Connection from RapidMiner Server _LOCAL
    2018-07-23 15:31:37.637 INFO 23995 --- [main] com.rapidminer : Loading 0 configurations of type Dropbox Connection from RapidMiner Server _LOCAL
    2018-07-23 15:31:37.640 INFO 23995 --- [main] com.rapidminer : Loading 0 configurations of type Salesforce Connection from RapidMiner Server _LOCAL
    2018-07-23 15:31:37.643 INFO 23995 --- [main] com.rapidminer : Loading 0 configurations of type Hive Connection from RapidMiner Server _LOCAL
    2018-07-23 15:31:37.647 INFO 23995 --- [main] com.rapidminer : Loading 0 configurations of type MongoDB Connection from RapidMiner Server _LOCAL
    2018-07-23 15:31:37.650 INFO 23995 --- [main] com.rapidminer : Loading 0 configurations of type Radoop Proxy Connection from RapidMiner Server _LOCAL
    2018-07-23 15:31:37.653 INFO 23995 --- [main] com.rapidminer : Loading 0 configurations of type Solr Connection from RapidMiner Server _LOCAL
    2018-07-23 15:31:37.656 INFO 23995 --- [main] com.rapidminer : Loading 0 configurations of type Splunk from RapidMiner Server _LOCAL
    2018-07-23 15:31:37.659 INFO 23995 --- [main] com.rapidminer : Loading 0 configurations of type Twitter Connection from RapidMiner Server _LOCAL
    2018-07-23 15:31:37.687 INFO 23995 --- [main] com.rapidminer : Loading 0 configurations of type MonkeyLearn API Key from RapidMiner Server _LOCAL
    2018-07-23 15:31:37.690 INFO 23995 --- [main] com.rapidminer : Loading 0 configurations of type Rosette Connection from RapidMiner Server _LOCAL
    2018-07-23 15:31:37.693 INFO 23995 --- [main] com.rapidminer : Loading 0 configurations of type SFTP Connection from RapidMiner Server _LOCAL
    2018-07-23 15:31:37.696 INFO 23995 --- [main] com.rapidminer : Loading 0 configurations of type Cassandra Connection from RapidMiner Server _LOCAL
    2018-07-23 15:31:37.698 INFO 23995 --- [main] com.rapidminer : Loading 0 configurations of type Amazon S3 Connection from RapidMiner Server _LOCAL
    2018-07-23 15:31:37.702 INFO 23995 --- [main] com.rapidminer : Loading 0 configurations of type Azure Blob Storage Connection from RapidMiner Server _LOCAL
    2018-07-23 15:31:37.705 INFO 23995 --- [main] com.rapidminer : Loading 0 configurations of type Dropbox Connection from RapidMiner Server _LOCAL
    2018-07-23 15:31:37.708 INFO 23995 --- [main] com.rapidminer : Loading 0 configurations of type Salesforce Connection from RapidMiner Server _LOCAL
    2018-07-23 15:31:37.710 INFO 23995 --- [main] com.rapidminer : Loading 0 configurations of type Hive Connection from RapidMiner Server _LOCAL
    2018-07-23 15:31:37.713 INFO 23995 --- [main] com.rapidminer : Loading 0 configurations of type MongoDB Connection from RapidMiner Server _LOCAL
    2018-07-23 15:31:37.716 INFO 23995 --- [main] com.rapidminer : Loading 0 configurations of type Radoop Proxy Connection from RapidMiner Server _LOCAL
    2018-07-23 15:31:37.718 INFO 23995 --- [main] com.rapidminer : Loading 0 configurations of type Solr Connection from RapidMiner Server _LOCAL
    2018-07-23 15:31:37.721 INFO 23995 --- [main] com.rapidminer : Loading 0 configurations of type Splunk from RapidMiner Server _LOCAL
    2018-07-23 15:31:37.724 INFO 23995 --- [main] com.rapidminer : Loading 0 configurations of type Twitter Connection from RapidMiner Server _LOCAL
    2018-07-23 15:31:38.007 INFO 23995 --- [main] com.rapidminer : Loading 0 configurations of type MonkeyLearn API Key from RapidMiner Server _LOCAL
    2018-07-23 15:31:38.010 INFO 23995 --- [main] com.rapidminer : Loading 0 configurations of type Rosette Connection from RapidMiner Server _LOCAL
    2018-07-23 15:31:38.012 INFO 23995 --- [main] com.rapidminer : Loading 0 configurations of type SFTP Connection from RapidMiner Server _LOCAL
    2018-07-23 15:31:38.015 INFO 23995 --- [main] com.rapidminer : Loading 0 configurations of type Cassandra Connection from RapidMiner Server _LOCAL
    2018-07-23 15:31:38.018 INFO 23995 --- [main] com.rapidminer : Loading 0 configurations of type Amazon S3 Connection from RapidMiner Server _LOCAL
    2018-07-23 15:31:38.021 INFO 23995 --- [main] com.rapidminer : Loading 0 configurations of type Azure Blob Storage Connection from RapidMiner Server _LOCAL
    2018-07-23 15:31:38.023 INFO 23995 --- [main] com.rapidminer : Loading 0 configurations of type Dropbox Connection from RapidMiner Server _LOCAL
    2018-07-23 15:31:38.026 INFO 23995 --- [main] com.rapidminer : Loading 0 configurations of type Salesforce Connection from RapidMiner Server _LOCAL
    2018-07-23 15:31:38.029 INFO 23995 --- [main] com.rapidminer : Loading 0 configurations of type Hive Connection from RapidMiner Server _LOCAL
    2018-07-23 15:31:38.031 INFO 23995 --- [main] com.rapidminer : Loading 0 configurations of type MongoDB Connection from RapidMiner Server _LOCAL
    2018-07-23 15:31:38.034 INFO 23995 --- [main] com.rapidminer : Loading 0 configurations of type Radoop Proxy Connection from RapidMiner Server _LOCAL
    2018-07-23 15:31:38.036 INFO 23995 --- [main] com.rapidminer : Loading 0 configurations of type Solr Connection from RapidMiner Server _LOCAL
    2018-07-23 15:31:38.039 INFO 23995 --- [main] com.rapidminer : Loading 0 configurations of type Splunk from RapidMiner Server _LOCAL
    2018-07-23 15:31:38.041 INFO 23995 --- [main] com.rapidminer : Loading 0 configurations of type Twitter Connection from RapidMiner Server _LOCAL
    2018-07-23 15:31:38.157 INFO 23995 --- [main] c.r.e.r.r.remote.ProcessServiceFacade : Setting up ProcessService v1.0
    2018-07-23 15:31:38.230 INFO 23995 --- [main] c.r.e.r.r.remote.ProcessServiceFacade : Setting up ProcessService v1.3
    2018-07-23 15:31:38.321 INFO 23995 --- [main] com.rapidminer.Process : No filename given for result file, using stdout for logging results!
    2018-07-23 15:31:38.325 INFO 23995 --- [main] c.r.e.j.e.ExecutionProcessListener : Execution of process started
    2018-07-23 15:31:38.326 INFO 23995 --- [main] com.rapidminer.Process : Process //_LOCAL/xxxxxxxxx starts
    2018-07-23 15:31:38.327 INFO 23995 --- [main] c.r.e.j.e.ExecutionProcessListener : Started operator 'Process (Process)'
    2018-07-23 15:31:38.329 INFO 23995 --- [main] c.r.e.j.e.ExecutionProcessListener : Started operator 'Radoop Nest (Radoop Nest)'
    2018-07-23 15:31:39.562 INFO 23995 --- [taskScheduler-2] c.r.e.j.service.OutOfMemoryWatchdog : Checking memory usage of Job Container
    2018-07-23 15:31:39.562 INFO 23995 --- [taskScheduler-2] c.r.e.j.service.OutOfMemoryWatchdog : Current memory usage is 6784MB / 16384MB
    2018-07-23 15:31:40.612 INFO 23995 --- [pool-6-thread-1] com.rapidminer : Getting radoop_hive-v4.jar file from plugin jar...
    2018-07-23 15:31:40.678 INFO 23995 --- [pool-6-thread-1] com.rapidminer : File uploaded: 95.30 KB written in 0 seconds (19.46 MB/sec)
    2018-07-23 15:31:40.833 INFO 23995 --- [pool-6-thread-1] com.rapidminer : Upload succeeded
    2018-07-23 15:31:40.846 INFO 23995 --- [main] c.r.e.j.e.ExecutionProcessListener : Started operator 'Read Database (15) (Read Database)'
    2018-07-23 15:31:41.108 INFO 23995 --- [main] com.rapidminer.Process : Executing query: 'SELECT * FROM `xxxxxxxxxxx`'
    2018-07-23 15:31:44.562 INFO 23995 --- [taskScheduler-2] c.r.e.j.service.OutOfMemoryWatchdog : Checking memory usage of Job Container
    2018-07-23 15:31:44.563 INFO 23995 --- [taskScheduler-2] c.r.e.j.service.OutOfMemoryWatchdog : Current memory usage is 6784MB / 16384MB
    2018-07-23 15:31:49.563 INFO 23995 --- [taskScheduler-2] c.r.e.j.service.OutOfMemoryWatchdog : Checking memory usage of Job Container
    2018-07-23 15:31:49.563 INFO 23995 --- [taskScheduler-2] c.r.e.j.service.OutOfMemoryWatchdog : Current memory usage is 6784MB / 16384MB
    2018-07-23 15:31:54.563 INFO 23995 --- [taskScheduler-2] c.r.e.j.service.OutOfMemoryWatchdog : Checking memory usage of Job Container
    2018-07-23 15:31:54.564 INFO 23995 --- [taskScheduler-2] c.r.e.j.service.OutOfMemoryWatchdog : Current memory usage is 6784MB / 16384MB
    2018-07-23 15:31:59.564 INFO 23995 --- [taskScheduler-2] c.r.e.j.service.OutOfMemoryWatchdog : Checking memory usage of Job Container
    2018-07-23 15:31:59.564 INFO 23995 --- [taskScheduler-2] c.r.e.j.service.OutOfMemoryWatchdog : Current memory usage is 6784MB / 16384MB
    2018-07-23 15:32:04.565 INFO 23995 --- [taskScheduler-2] c.r.e.j.service.OutOfMemoryWatchdog : Checking memory usage of Job Container
    2018-07-23 15:32:04.565 INFO 23995 --- [taskScheduler-2] c.r.e.j.service.OutOfMemoryWatchdog : Current memory usage is 6784MB / 16384MB
    2018-07-23 15:32:09.565 INFO 23995 --- [taskScheduler-2] c.r.e.j.service.OutOfMemoryWatchdog : Checking memory usage of Job Container
    2018-07-23 15:32:09.565 INFO 23995 --- [taskScheduler-2] c.r.e.j.service.OutOfMemoryWatchdog : Current memory usage is 6784MB / 16384MB
    2018-07-23 15:32:14.566 INFO 23995 --- [taskScheduler-3] c.r.e.j.service.OutOfMemoryWatchdog : Checking memory usage of Job Container
    2018-07-23 15:32:14.567 INFO 23995 --- [taskScheduler-3] c.r.e.j.service.OutOfMemoryWatchdog : Current memory usage is 6784MB / 16384MB
    2018-07-23 15:32:19.567 INFO 23995 --- [taskScheduler-3] c.r.e.j.service.OutOfMemoryWatchdog : Checking memory usage of Job Container
    2018-07-23 15:32:19.567 INFO 23995 --- [taskScheduler-3] c.r.e.j.service.OutOfMemoryWatchdog : Current memory usage is 6784MB / 16384MB
    2018-07-23 15:32:24.567 INFO 23995 --- [taskScheduler-3] c.r.e.j.service.OutOfMemoryWatchdog : Checking memory usage of Job Container
    2018-07-23 15:32:24.568 INFO 23995 --- [taskScheduler-3] c.r.e.j.service.OutOfMemoryWatchdog : Current memory usage is 6784MB / 16384MB
    2018-07-23 15:32:29.568 INFO 23995 --- [taskScheduler-3] c.r.e.j.service.OutOfMemoryWatchdog : Checking memory usage of Job Container
    2018-07-23 15:32:29.568 INFO 23995 --- [taskScheduler-3] c.r.e.j.service.OutOfMemoryWatchdog : Current memory usage is 6784MB / 16384MB
    2018-07-23 15:32:34.568 INFO 23995 --- [taskScheduler-3] c.r.e.j.service.OutOfMemoryWatchdog : Checking memory usage of Job Container
    2018-07-23 15:32:34.569 INFO 23995 --- [taskScheduler-3] c.r.e.j.service.OutOfMemoryWatchdog : Current memory usage is 6784MB / 16384MB
    2018-07-23 15:32:39.569 INFO 23995 --- [taskScheduler-3] c.r.e.j.service.OutOfMemoryWatchdog : Checking memory usage of Job Container
    2018-07-23 15:32:39.569 INFO 23995 --- [taskScheduler-3] c.r.e.j.service.OutOfMemoryWatchdog : Current memory usage is 6784MB / 16384MB
    2018-07-23 15:32:44.569 INFO 23995 --- [taskScheduler-3] c.r.e.j.service.OutOfMemoryWatchdog : Checking memory usage of Job Container
    2018-07-23 15:32:44.570 INFO 23995 --- [taskScheduler-3] c.r.e.j.service.OutOfMemoryWatchdog : Current memory usage is 6784MB / 16384MB
    2018-07-23 15:32:49.570 INFO 23995 --- [taskScheduler-3] c.r.e.j.service.OutOfMemoryWatchdog : Checking memory usage of Job Container
    2018-07-23 15:32:49.570 INFO 23995 --- [taskScheduler-3] c.r.e.j.service.OutOfMemoryWatchdog : Current memory usage is 6784MB / 16384MB
    2018-07-23 15:32:54.570 INFO 23995 --- [taskScheduler-3] c.r.e.j.service.OutOfMemoryWatchdog : Checking memory usage of Job Container
    2018-07-23 15:32:54.571 INFO 23995 --- [taskScheduler-3] c.r.e.j.service.OutOfMemoryWatchdog : Current memory usage is 6784MB / 16384MB
    2018-07-23 15:32:59.571 INFO 23995 --- [taskScheduler-3] c.r.e.j.service.OutOfMemoryWatchdog : Checking memory usage of Job Container
    2018-07-23 15:32:59.571 INFO 23995 --- [taskScheduler-3] c.r.e.j.service.OutOfMemoryWatchdog : Current memory usage is 6784MB / 16384MB
    2018-07-23 15:33:04.571 INFO 23995 --- [taskScheduler-3] c.r.e.j.service.OutOfMemoryWatchdog : Checking memory usage of Job Container
    2018-07-23 15:33:04.572 INFO 23995 --- [taskScheduler-3] c.r.e.j.service.OutOfMemoryWatchdog : Current memory usage is 6784MB / 16384MB
    2018-07-23 15:33:09.572 INFO 23995 --- [taskScheduler-3] c.r.e.j.service.OutOfMemoryWatchdog : Checking memory usage of Job Container
    2018-07-23 15:33:09.572 INFO 23995 --- [taskScheduler-3] c.r.e.j.service.OutOfMemoryWatchdog : Current memory usage is 6784MB / 16384MB
    2018-07-23 15:33:14.572 INFO 23995 --- [taskScheduler-3] c.r.e.j.service.OutOfMemoryWatchdog : Checking memory usage of Job Container
    2018-07-23 15:33:14.573 INFO 23995 --- [taskScheduler-3] c.r.e.j.service.OutOfMemoryWatchdog : Current memory usage is 6784MB / 16384MB
    2018-07-23 15:33:19.573 INFO 23995 --- [taskScheduler-3] c.r.e.j.service.OutOfMemoryWatchdog : Checking memory usage of Job Container
    2018-07-23 15:33:19.573 INFO 23995 --- [taskScheduler-3] c.r.e.j.service.OutOfMemoryWatchdog : Current memory usage is 6784MB / 16384MB
    2018-07-23 15:33:24.573 INFO 23995 --- [taskScheduler-3] c.r.e.j.service.OutOfMemoryWatchdog : Checking memory usage of Job Container
    2018-07-23 15:33:24.574 INFO 23995 --- [taskScheduler-3] c.r.e.j.service.OutOfMemoryWatchdog : Current memory usage is 6784MB / 16384MB
    2018-07-23 15:33:29.574 INFO 23995 --- [taskScheduler-3] c.r.e.j.service.OutOfMemoryWatchdog : Checking memory usage of Job Container
    2018-07-23 15:33:29.574 INFO 23995 --- [taskScheduler-3] c.r.e.j.service.OutOfMemoryWatchdog : Current memory usage is 6784MB / 16384MB
    2018-07-23 15:33:34.574 INFO 23995 --- [taskScheduler-3] c.r.e.j.service.OutOfMemoryWatchdog : Checking memory usage of Job Container
    2018-07-23 15:33:34.575 INFO 23995 --- [taskScheduler-3] c.r.e.j.service.OutOfMemoryWatchdog : Current memory usage is 6784MB / 16384MB
    2018-07-23 15:33:39.575 INFO 23995 --- [taskScheduler-3] c.r.e.j.service.OutOfMemoryWatchdog : Checking memory usage of Job Container
    2018-07-23 15:33:39.575 INFO 23995 --- [taskScheduler-3] c.r.e.j.service.OutOfMemoryWatchdog : Current memory usage is 6784MB / 16384MB
    2018-07-23 15:33:44.576 INFO 23995 --- [taskScheduler-3] c.r.e.j.service.OutOfMemoryWatchdog : Checking memory usage of Job Container
    2018-07-23 15:33:44.576 INFO 23995 --- [taskScheduler-3] c.r.e.j.service.OutOfMemoryWatchdog : Current memory usage is 6784MB / 16384MB
    2018-07-23 15:33:49.576 INFO 23995 --- [taskScheduler-3] c.r.e.j.service.OutOfMemoryWatchdog : Checking memory usage of Job Container
    2018-07-23 15:33:49.576 INFO 23995 --- [taskScheduler-3] c.r.e.j.service.OutOfMemoryWatchdog : Current memory usage is 6784MB / 16384MB
    2018-07-23 15:33:54.577 INFO 23995 --- [taskScheduler-3] c.r.e.j.service.OutOfMemoryWatchdog : Checking memory usage of Job Container
    2018-07-23 15:33:54.577 INFO 23995 --- [taskScheduler-3] c.r.e.j.service.OutOfMemoryWatchdog : Current memory usage is 6784MB / 16384MB
    2018-07-23 15:33:59.577 INFO 23995 --- [taskScheduler-3] c.r.e.j.service.OutOfMemoryWatchdog : Checking memory usage of Job Container
    2018-07-23 15:33:59.577 INFO 23995 --- [taskScheduler-3] c.r.e.j.service.OutOfMemoryWatchdog : Current memory usage is 6912MB / 16384MB
    2018-07-23 15:34:04.578 INFO 23995 --- [taskScheduler-3] c.r.e.j.service.OutOfMemoryWatchdog : Checking memory usage of Job Container
    2018-07-23 15:34:04.578 INFO 23995 --- [taskScheduler-3] c.r.e.j.service.OutOfMemoryWatchdog : Current memory usage is 7104MB / 16384MB
    2018-07-23 15:34:09.578 INFO 23995 --- [taskScheduler-3] c.r.e.j.service.OutOfMemoryWatchdog : Checking memory usage of Job Container
    2018-07-23 15:34:09.578 INFO 23995 --- [taskScheduler-3] c.r.e.j.service.OutOfMemoryWatchdog : Current memory usage is 7104MB / 16384MB
    2018-07-23 15:34:14.579 INFO 23995 --- [taskScheduler-3] c.r.e.j.service.OutOfMemoryWatchdog : Checking memory usage of Job Container
    2018-07-23 15:34:14.579 INFO 23995 --- [taskScheduler-3] c.r.e.j.service.OutOfMemoryWatchdog : Current memory usage is 7360MB / 16384MB
    2018-07-23 15:34:19.579 INFO 23995 --- [taskScheduler-3] c.r.e.j.service.OutOfMemoryWatchdog : Checking memory usage of Job Container
    2018-07-23 15:34:19.580 INFO 23995 --- [taskScheduler-3] c.r.e.j.service.OutOfMemoryWatchdog : Current memory usage is 7488MB / 16384MB
    2018-07-23 15:34:24.580 INFO 23995 --- [taskScheduler-3] c.r.e.j.service.OutOfMemoryWatchdog : Checking memory usage of Job Container
    2018-07-23 15:34:24.580 INFO 23995 --- [taskScheduler-3] c.r.e.j.service.OutOfMemoryWatchdog : Current memory usage is 7488MB / 16384MB
    2018-07-23 15:34:29.581 INFO 23995 --- [taskScheduler-3] c.r.e.j.service.OutOfMemoryWatchdog : Checking memory usage of Job Container
    2018-07-23 15:34:29.581 INFO 23995 --- [taskScheduler-3] c.r.e.j.service.OutOfMemoryWatchdog : Current memory usage is 7840MB / 16384MB
    2018-07-23 15:34:34.581 INFO 23995 --- [taskScheduler-3] c.r.e.j.service.OutOfMemoryWatchdog : Checking memory usage of Job Container
    2018-07-23 15:34:34.581 INFO 23995 --- [taskScheduler-3] c.r.e.j.service.OutOfMemoryWatchdog : Current memory usage is 7840MB / 16384MB
    2018-07-23 15:34:39.582 INFO 23995 --- [taskScheduler-5] c.r.e.j.service.OutOfMemoryWatchdog : Checking memory usage of Job Container
    2018-07-23 15:34:39.582 INFO 23995 --- [taskScheduler-5] c.r.e.j.service.OutOfMemoryWatchdog : Current memory usage is 8192MB / 16384MB
    2018-07-23 15:34:44.582 INFO 23995 --- [taskScheduler-5] c.r.e.j.service.OutOfMemoryWatchdog : Checking memory usage of Job Container
    2018-07-23 15:34:44.833 INFO 23995 --- [taskScheduler-5] c.r.e.j.service.OutOfMemoryWatchdog : Current memory usage is 8640MB / 16384MB
    2018-07-23 15:34:49.833 INFO 23995 --- [taskScheduler-5] c.r.e.j.service.OutOfMemoryWatchdog : Checking memory usage of Job Container
    2018-07-23 15:34:49.833 INFO 23995 --- [taskScheduler-5] c.r.e.j.service.OutOfMemoryWatchdog : Current memory usage is 8640MB / 16384MB
    2018-07-23 15:34:54.833 INFO 23995 --- [taskScheduler-5] c.r.e.j.service.OutOfMemoryWatchdog : Checking memory usage of Job Container
    2018-07-23 15:34:54.834 INFO 23995 --- [taskScheduler-5] c.r.e.j.service.OutOfMemoryWatchdog : Current memory usage is 8960MB / 16384MB
    2018-07-23 15:34:59.834 INFO 23995 --- [taskScheduler-5] c.r.e.j.service.OutOfMemoryWatchdog : Checking memory usage of Job Container
    2018-07-23 15:34:59.834 INFO 23995 --- [taskScheduler-5] c.r.e.j.service.OutOfMemoryWatchdog : Current memory usage is 9088MB / 16384MB
    2018-07-23 15:35:04.834 INFO 23995 --- [taskScheduler-5] c.r.e.j.service.OutOfMemoryWatchdog : Checking memory usage of Job Container
    2018-07-23 15:35:04.835 INFO 23995 --- [taskScheduler-5] c.r.e.j.service.OutOfMemoryWatchdog : Current memory usage is 9088MB / 16384MB
    2018-07-23 15:35:09.835 INFO 23995 --- [taskScheduler-5] c.r.e.j.service.OutOfMemoryWatchdog : Checking memory usage of Job Container
    2018-07-23 15:35:09.835 INFO 23995 --- [taskScheduler-5] c.r.e.j.service.OutOfMemoryWatchdog : Current memory usage is 9344MB / 16384MB
    2018-07-23 15:35:14.835 INFO 23995 --- [taskScheduler-5] c.r.e.j.service.OutOfMemoryWatchdog : Checking memory usage of Job Container
    2018-07-23 15:35:14.836 INFO 23995 --- [taskScheduler-5] c.r.e.j.service.OutOfMemoryWatchdog : Current memory usage is 9344MB / 16384MB
    2018-07-23 15:35:19.836 INFO 23995 --- [taskScheduler-5] c.r.e.j.service.OutOfMemoryWatchdog : Checking memory usage of Job Container
    2018-07-23 15:35:19.836 INFO 23995 --- [taskScheduler-5] c.r.e.j.service.OutOfMemoryWatchdog : Current memory usage is 9760MB / 16384MB
    2018-07-23 15:35:24.836 INFO 23995 --- [taskScheduler-5] c.r.e.j.service.OutOfMemoryWatchdog : Checking memory usage of Job Container
    2018-07-23 15:35:24.837 INFO 23995 --- [taskScheduler-5] c.r.e.j.service.OutOfMemoryWatchdog : Current memory usage is 9760MB / 16384MB
    2018-07-23 15:35:29.837 INFO 23995 --- [taskScheduler-3] c.r.e.j.service.OutOfMemoryWatchdog : Checking memory usage of Job Container
    2018-07-23 15:35:29.837 INFO 23995 --- [taskScheduler-3] c.r.e.j.service.OutOfMemoryWatchdog : Current memory usage is 10304MB / 16384MB
    2018-07-23 15:35:34.837 INFO 23995 --- [taskScheduler-3] c.r.e.j.service.OutOfMemoryWatchdog : Checking memory usage of Job Container
    2018-07-23 15:35:34.838 INFO 23995 --- [taskScheduler-3] c.r.e.j.service.OutOfMemoryWatchdog : Current memory usage is 10304MB / 16384MB
    2018-07-23 15:35:39.838 INFO 23995 --- [taskScheduler-3] c.r.e.j.service.OutOfMemoryWatchdog : Checking memory usage of Job Container
    2018-07-23 15:35:39.838 INFO 23995 --- [taskScheduler-3] c.r.e.j.service.OutOfMemoryWatchdog : Current memory usage is 10304MB / 16384MB
    2018-07-23 15:35:44.838 INFO 23995 --- [taskScheduler-3] c.r.e.j.service.OutOfMemoryWatchdog : Checking memory usage of Job Container
    2018-07-23 15:35:44.839 INFO 23995 --- [taskScheduler-3] c.r.e.j.service.OutOfMemoryWatchdog : Current memory usage is 10720MB / 16384MB
    2018-07-23 15:35:49.839 INFO 23995 --- [taskScheduler-3] c.r.e.j.service.OutOfMemoryWatchdog : Checking memory usage of Job Container
    2018-07-23 15:35:49.839 INFO 23995 --- [taskScheduler-3] c.r.e.j.service.OutOfMemoryWatchdog : Current memory usage is 10720MB / 16384MB
    2018-07-23 15:35:54.839 INFO 23995 --- [taskScheduler-3] c.r.e.j.service.OutOfMemoryWatchdog : Checking memory usage of Job Container
    2018-07-23 15:35:54.840 INFO 23995 --- [taskScheduler-3] c.r.e.j.service.OutOfMemoryWatchdog : Current memory usage is 11328MB / 16384MB
    2018-07-23 15:35:59.840 INFO 23995 --- [taskScheduler-3] c.r.e.j.service.OutOfMemoryWatchdog : Checking memory usage of Job Container
    2018-07-23 15:35:59.840 INFO 23995 --- [taskScheduler-3] c.r.e.j.service.OutOfMemoryWatchdog : Current memory usage is 11328MB / 16384MB
    2018-07-23 15:36:04.840 INFO 23995 --- [taskScheduler-3] c.r.e.j.service.OutOfMemoryWatchdog : Checking memory usage of Job Container
    2018-07-23 15:36:04.841 INFO 23995 --- [taskScheduler-3] c.r.e.j.service.OutOfMemoryWatchdog : Current memory usage is 11328MB / 16384MB
    2018-07-23 15:36:09.841 INFO 23995 --- [taskScheduler-3] c.r.e.j.service.OutOfMemoryWatchdog : Checking memory usage of Job Container
    2018-07-23 15:36:09.841 INFO 23995 --- [taskScheduler-3] c.r.e.j.service.OutOfMemoryWatchdog : Current memory usage is 11712MB / 16384MB
    2018-07-23 15:36:14.841 INFO 23995 --- [taskScheduler-3] c.r.e.j.service.OutOfMemoryWatchdog : Checking memory usage of Job Container
    2018-07-23 15:36:14.842 INFO 23995 --- [taskScheduler-3] c.r.e.j.service.OutOfMemoryWatchdog : Current memory usage is 11712MB / 16384MB
    2018-07-23 15:36:19.918 INFO 23995 --- [taskScheduler-3] c.r.e.j.service.OutOfMemoryWatchdog : Checking memory usage of Job Container
    2018-07-23 15:36:19.919 INFO 23995 --- [taskScheduler-3] c.r.e.j.service.OutOfMemoryWatchdog : Current memory usage is 12096MB / 16384MB
    2018-07-23 15:36:24.919 INFO 23995 --- [taskScheduler-3] c.r.e.j.service.OutOfMemoryWatchdog : Checking memory usage of Job Container
    2018-07-23 15:36:24.919 INFO 23995 --- [taskScheduler-3] c.r.e.j.service.OutOfMemoryWatchdog : Current memory usage is 12096MB / 16384MB
    2018-07-23 15:36:29.9
    User: "sgenzer"
    Altair Employee
    hi @JEdward - sorry some of the Radoop folks are on vacation at the moment (and this is out of my league!). I will see if I can track somebody down for you.
    Scott
    User: "jpuente"
    Altair Employee
    Hi,
    That's not the expected behaviour, for sure. We'll try to reproduce on our side and we'll get back to you.
    Jesús
    User: "asimon"
    Hi,
    Could you please send us your process xml? That would help a lot in the reproduction.
    Thanks,
    Attila
    User: "JEdward"
    OP
    Not really much exciting to see.
    Please note, I changed the connection names for posting.  I am using Radoop BETA here, but the same occurred in the older version too.    Database is moving from an AWS RDS MySQL database into a cluster hosted outside AWS.   Could this be something to do with it?
    <?xml version="1.0" encoding="UTF-8"?><process version="8.2.001">
    <context>
    <input/>
    <output/>
    <macros/>
    </context>
    <operator activated="true" class="process" compatibility="8.2.001" expanded="true" name="Process">
    <process expanded="true">
    <operator activated="true" class="radoop:radoop_nest" compatibility="9.0.000-BETA" expanded="true" height="82" name="Radoop Nest" width="90" x="179" y="34">
    <parameter key="connection" value="666"/>
    <parameter key="change_sample_size" value="true"/>
    <parameter key="sample_size" value="100"/>
    <enumeration key="tables_to_reload"/>
    <operator activated="true" class="radoop:read_db" compatibility="9.0.000-BETA" expanded="true" height="68" name="Read Database (15)" width="90" x="112" y="85">
    <parameter key="connection" value="AWSRDS"/>
    <parameter key="define_query" value="table name"/>
    <parameter key="table_name" value="myTable"/>
    <enumeration key="parameters"/>
    <parameter key="temporary_table" value="false"/>
    <parameter key="saved_table_name" value="trip_position3"/>
    </operator>
    <connect from_op="Read Database (15)" from_port="output" to_port="output 1"/>
    <portSpacing port="source_input 2" spacing="0"/>
    <portSpacing port="sink_output 1" spacing="0"/>
    <portSpacing port="sink_output 2" spacing="0"/>
    </process>
    </operator>
    </process>
    </operator>
    </process>
    User: "JEdward"
    OP
    Any luck replicating this error?  It would be great if it is something simple that can be resolved with the RM 9 release.
    I'm stumped this end as the error logs don't give me any clues.
    User: "JEdward"
    OP
    @asimon @jpuente
    Were you able to reproduce this on your side?
    I've just upgraded from RM Server 8.2 to RM Server 9.01 and can confirm it is still happening on my side.
    My "workaround" of reading in snapshots of the database and then combining them all at the end is rather cumbersome.
    I would expect the database to open as a stream, but it doesn't seem to want to... just wants to load it all into memory.
