"Getting CTA DB error message with web crawler - help!"
I'm trying to use the crawl web operator in studio version 7.6.001 and as soon as the crawler starts I get the following in the log "Not able to connect to the CTA DB" and then after a while the operation just times out. I can't figure out what's going on. It seems to be related to these specific operators because I can use others without a problem. Anyone have any ideas?
1 - 3 of
31
<?xml version="1.0" encoding="UTF-8"?><process version="7.6.001">
<context>
<input/>
<output/>
<macros/>
</context>
<operator activated="true" class="process" compatibility="7.6.001" expanded="true" name="Process">
<process expanded="true">
<operator activated="true" class="web:crawl_web_modern" compatibility="7.3.000" expanded="true" height="68" name="Crawl Web" width="90" x="246" y="187">
<parameter key="url" value="http://parker.com"/>
<list key="crawling_rules">
<parameter key="store_with_matching_url" value="*parker.com*"/>
</list>
<parameter key="max_crawl_depth" value="3"/>
<parameter key="retrieve_as_html" value="true"/>
<parameter key="write_pages_to_disk" value="true"/>
<parameter key="include_binary_content" value="true"/>
<parameter key="output_dir" value="C:\Users\533537\Desktop\webPages"/>
<parameter key="ignore_robot_exclusion" value="true"/>
</operator>
<connect from_op="Crawl Web" from_port="example set" to_port="result 1"/>
</process>
</operator>
</process>
Hi Michael,
it seems that you have an error in the regex field of the crawling rules. "*parker.com*" is not a valid expression. What exactly have been your intentions with that expression? Capture everything that contains "parker.com", no matter what elements are before or after that? If so, try this expression (without quotation marks): ".*parker.com.*"
hello @michael_crowdes - welcome to the RapidMiner Community. Could you post your XML in this thread so we can see your process? Please use the </> tool.
Thanks.
Scott
