Message error: "could not contact license server"
Hi, I installed rapid miner studio but when I try to run the application a sign up screen appears. After tipying the required information the software gave me the message I wrote in the subjetc. Any idea of what is going on?.
Regards,
Flavio
Hi Nils,
I've got the same error message (Could not contact license server) when I try to login when I'm using my work laptop. When I login at home this does not happen. I've got version 7.2.003 at work and 7.2.001 at home. Maybe thats why? Or maybe it has something to do with a firewall or some other security measure? Can you tell me how I can login when I'm using my work laptop?
Thanks in advance for your help.
(Also) Nils
Hi all,
RapidMiner Studio does not require an internet connection and as consequence you can use RapidMiner Studio without having an active conntection to the license server.
Just follow the steps below to get Studio running without contacting the license server:
1. Studio starts for first time, click on I've already an account
2. Click on manually enter a license key
3. Enter the license manually
If you don't have any license, just register/ login on https://my.rapidminer.com/nexus/account/index.html to retrieve a free license key.
Cheers,
Marcel
I have exactly the same issue right now. Can't use rapidminer
