NoClassDefFoundError Could not initialize class org.apache.hadoop.yarn.conf.YarnConfiguration
Hi,
I try run Hadoop with single mode on Rapidminer. Howerver, I got issue . I using Rapidminer Studio 7.5
java.util.concurrent.ExecutionException: java.lang.NoClassDefFoundError: Could not initialize class org.apache.hadoop.yarn.conf.YarnConfiguration
at java.util.concurrent.FutureTask.report(FutureTask.java:122)
at java.util.concurrent.FutureTask.get(FutureTask.java:192)
at com.rapidminer.pagerank.utilities.HadoopUtilities.runHadoopLocal(HadoopUtilities.java:173)
at com.rapidminer.pagerank.operator.PageRankOperator.doWork(PageRankOperator.java:78)
at com.rapidminer.operator.Operator.execute(Operator.java:1004)
at com.rapidminer.operator.execution.SimpleUnitExecutor.execute(SimpleUnitExecutor.java:77)
at com.rapidminer.operator.ExecutionUnit$3.run(ExecutionUnit.java:812)
at com.rapidminer.operator.ExecutionUnit$3.run(ExecutionUnit.java:1)
at java.security.AccessController.doPrivileged(Native Method)
at com.rapidminer.operator.ExecutionUnit.execute(ExecutionUnit.java:807)
at com.rapidminer.operator.OperatorChain.doWork(OperatorChain.java:428)
at com.rapidminer.Process.run(Process.java:1315)
at com.rapidminer.Process.run(Process.java:1179)
at com.rapidminer.Process.run(Process.java:1132)
at com.rapidminer.Process.run(Process.java:1127)
at com.rapidminer.Process.run(Process.java:1117)
at com.rapidminer.gui.ProcessThread.run(ProcessThread.java:65)
In build.gradle
dependencies {
//compile 'com.google.guava:guava:18.0'
compile "org.apache.hadoop:hadoop-hdfs:2.7.3"
compile "org.apache.hadoop:hadoop-client:2.7.3"
compile "org.apache.hadoop:hadoop-mapreduce-client-core:2.7.3"
compile "org.apache.hadoop:hadoop-yarn-common:2.7.3"
compile "org.apache.hadoop:hadoop-mapreduce-client-jobclient:2.7.3"
compile "org.apache.hadoop:hadoop-yarn-client:2.7.3"
compile "org.apache.hadoop:hadoop-yarn:2.7.3"
compile "org.apache.hadoop:hadoop-common:2.7.3"
Can everyone help me?
1 - 8 of
81
Thanks you so much.
However, When I run in Eclipse with Hadoop single mode && cluster mode , it's ok .
After I install my extension , I run extension in Rapidminer, occur exception.
I don't know, How to add classpath in extension of Rapidminer ? Can you provide for me one example ?
Sorry, I speak english not good.
Hi,
Could you please check if the Yarn class path is defined in the following XML file:
YARN configuration XML could be found here: /etc/hadoop/conf/yarn-site.xml
user@linux$ sudo vi /etc/hadoop/conf/yarn-site.xml
<property>
<name>yarn.application.classpath</name>
<value>
$HADOOP_CONF_DIR,
$HADOOP_COMMON_HOME/*,
$HADOOP_COMMON_HOME/lib/*,
$HADOOP_HDFS_HOME/*,
$HADOOP_HDFS_HOME/lib/*,
$HADOOP_MAPRED_HOME/*,
$HADOOP_MAPRED_HOME/lib/*,
$YARN_HOME/*,
$YARN_HOME/lib/*,
/etc/hadoop/conf,
/usr/lib/hadoop/*,
/usr/lib/hadoop/lib,
/usr/lib/hadoop/lib/*,
/usr/lib/hadoop-hdfs,
/usr/lib/hadoop-hdfs/*,
/usr/lib/hadoop-hdfs/lib/*,
/usr/lib/hadoop-yarn/*,
/usr/lib/hadoop-yarn/lib/*,
/usr/lib/hadoop-mapreduce/*,
/usr/lib/hadoop-mapreduce/lib/*
</value>
</property>
Cheers,
Help me
