"Rapid Miner crashes after installing and configuring R extension"
Hi,
I am trying to make the R extension work. Unfortunately, Rapid Miner crashes on startup.
I have set the system variables as follows:
Moreover: is there a log file to understand what happened during the crash?
thanks!
C:\Users\stablum>echo %PATH%
...stuff stuff stuff...;C:\Program Files\R\R-3.0.0\bin\x64;... stuff stuff stuff...
C:\Users\stablum>echo %JAVA_HOME%
C:\Program Files\Java\jre7
C:\Users\stablum>echo %R_HOME%any ideas?
"C:\Program Files\R\R-3.0.0"
thanks!
1 - 4 of
41
which version of RapidMiner and R extension are you using?
The RapidMiner logfile can be found in %USER_FOLDER%/.RapidMiner5
Best,
Nils
