🎉Community Raffle - Win $25
Join and Win
"[SOLVED] How to set macros via Java code?"
User: "sixofone"
New Altair Community Member
Updated by Jocelyn
Hi, I have a small Java app that runs a RapidMiner 5.3 process and it is working pretty well.
Recently, we added the ability to set macro values via the RapidMiner command line and now I need to add support for setting the macro values to my Java code and can't seem to find how to do that. I would think this should be relatively simple to do. Does any example code snippets exist?
Following is a snippet of my current RapidMiner related code:
RapidMiner.setExecutionMode(ExecutionMode.COMMAND_LINE);
RapidMiner.init();
Process rm5 = new Process(new File("/home/petes/Documents/NewRmRepository/FindObjectsStep3Clusters.rmp"));
rm5.run();
Thanks for any guidance or suggestions.
Pete
1 - 6 of 61
    User: "Skirzynski"
    Pair<String, String> macro = new Pair<String, String>("macro", "value")
    rm5.getContext().addMacro(macro);
    By the way, when you start RapidMiner from the command line you are already able to set the macros with the -Mname=value switch.
    User: "sixofone"
    OP
    thanks for the quick reply and sample!
    yes, I know we can set the macros from the command and we use that a lot now.  You could consider my app a wrapper of sorts around the command line executions for several RapidMiner processes that should be executed in a specific order and we run them via cron daily.  A gross oversimplification but some context for what I am doing here.
    thanks again
    User: "Skirzynski"
    It seems that RapidAnalytics can do this for you as well, so this could be an alternative? Nevertheless, if you are integrating RapidMiner in your program don't forget to choose the proper license or contact our sales team.  ;)
    Happy hacking!
      Marcin
    User: "sixofone"
    OP
    Marcin,
    We have heard RapidAnalytics does most of what I really want to do and I have that on my task list to trial in the near future.  I do understand the licensing considerations and in our current state, researching practical uses for our analytics, this is used internally by my team. Depending on our results and our trial of RapidAnalytics, this code my never see broad use but is a great learning experience for me in any case.  ::)
    In followup to your suggestion, please excuse my Java / RapidMiner ignorance, but when I added the following code:
    import com.rapidminer.tools.container.Pair;
    Pair<String, String> macro = Pair<String, String> ("query_type", "0");
    The following errors are reported via eclipse:
    On the Pair to the right of =  error > Pair cannot be resolved to a variable
    On "query_type"  error > The left-hand side of an assignment must be a variable
    I suspect am missing something basic but any guidance would be appreciated.
    thanks again
    Pete
    User: "Skirzynski"
    Sorry, this was my fault. Of course you have to create the pair object. The "new" keyword is missing.
    Pair<String, String> macro = new Pair<String, String>("query_type", "0");
    User: "sixofone"
    OP
    well a big DOH to me - I should have caught that !  :o
    thanks again...
    works as expected!!!  ;D
