🎉Community Raffle - Win $25
Join and Win
"Clustering in Rapidminer and R extension"
User: "nav"
New Altair Community Member
Updated by Jocelyn
Hello,
I am not new of rapidminer but I am new of R extension. I need to use R for calculate same statistics for the clustering output from rapidminer operator, but I don't now how to use the cluster set of rapidminer in the R script operator (I have already use the R export operatore). In particular what I want to do is for example:
- do different clustering with rapidminer operator
- apply some statics from R script to the example set of previous step, for example randIndex, silhuette, etc
But how can I use the example set of clustering in R.
Thanks in advance to all.
1 - 3 of 31
    User: "nav"
    OP
    Possible that none never had the need of using R to calculate any statistics from a cluster set generated by RapidMiner operator?
    User: "Andrew2"
    Hello
    I made a comment on my http://rapidminernotes.blogspot.com/2011/06/counting-clusters-part-r.html
    The key part is the R needed
    library(mclust)
    library(profdpm)
    ## "data" is defined as the input in the inputs
    ## each column is referred to by name using $
    ## because the input is a data frame.
    ARI = adjustedRandIndex(data$cluster1, data$cluster2)
    ARI = as.data.frame(ARI)
    pci=as.data.frame(t(pci(data$cluster1, data$cluster2)))
    ## using the variable ari sets the name of the returned data frame column
    ## and avoids having to use a rename process
    ## "x" is the output defined in the results
    ## it must be a data frame
    x = as.data.frame(cbind(ARI,pci))
    Andrew
    User: "nav"
    OP
    Thank you very much... you give me a very good starting point for my problem...
