How to export files from Simlab for use on Optistruct?
Bi.EMS
Bi.EMS Altair Community Member
edited April 2023 in Community Q&A
Hi all,
I am doing meshing for the model. However, I found that creating mesh on Optistruct gives worse results than creating mesh on Simlab . So if I perform meshing on Simlab, how can I export a file containing mesh information to optistruct for use (conditions, materials, .. I want to do it on Optistruct).
Thank you.
Welcome!
Answers
  • AlessioLibrandi
    AlessioLibrandi
    Altair Employee
    edited April 2023
    Hello,
    before starting with the Setup, please define a Solution for Optistruct from the solution Menu:
    The solution will be shown in your Solution Browser.
    Once you defined all needed settings and LBCs, right click on the solution name to export it as an Input File *.fem:
    I hope this helps.
    Thanks
    Alessio Librandi
  • Bi.EMS
    edited April 2023
    Hello,
    I hope this helps.
    Thanks
    Alessio Librandi
    thank you very much
  • Bi.EMS
    edited April 2023
    Hello,
    I hope this helps.
    Thanks
    Alessio Librandi
    I did the same as you instructed. After exporting the file from simlab, I proceeded to import the file into optistruct to create contact, Howeverthe contact creation is very long (red circled area in the image). So what error am I facingThank you. image
  • AlessioLibrandi
    AlessioLibrandi
    Altair Employee
    edited April 2023
    Hello, I would rather post this question in the Hyperworks forum, you would get surely better answers there.  Anyway SimLab has also the possibility of creating easily contacts, you can try it as well before exporting.
  • Bi.EMS
    edited April 2023
    Thank you very much, if you have an answer please send it to me
Welcome!
Welcome!
