Description:
I am having a licensing issue with PSIM 2026.1 Student Edition.
I successfully obtained and activated my Student Edition license using the Altair License Utility.
My current setup is:
- PSIM version: PSIM 2026.1
- License Store: System
- The
.lic file was successfully created in C:\ProgramData\altair\licenses ALTAIR_LICENSE_PATH points to the generated .lic file.ALM_HHWU is set to F.- PSIM License Setup shows “This computer is authorized.”
- Motor Drive is selected under Features.
PSIM itself launches successfully. However, when I select File → New to create a new schematic, nothing happens. I have also received the following error:
“Connection to the license server is lost. The application will shut down.”
I checked the generated .lic file in a text editor and searched for “PSIM”, but there are no PSIM-related entries in the license file.
Could you please check whether the Student Edition license issued to my account contains the required PSIM 2026.1 features/entitlements?
If the PSIM features are missing, could you please reset or reissue the Student Edition license with the appropriate PSIM entitlement?
Thank you.
iption here
Product/Topic Name : psim 2026.1
*Note from Community Team - Once you receive a satisfactory answer on your question, kindly mark your answers as "Accepted" so it can help others with similar problems. Thanks.
