Hello everyone,
- I see that in tutorials an inductance in the motor circuit is defined but I do not understand how this is calculated. Could you please provide a help in calculating this value for an axial-flux motor? The inductance changes with the rotor position, so how could I already give it as input in the circuit parameters?
- If this inductance is referred to the end windings, then what will happen if I define a circuit with no end winding inductance? Will Altair Simlab calculate this automatically, without me imposing a value for that? To be more clear I will write you here what I want hoping that someone of you could help me with that:
I want to get the phase inductance without having to impose an end-winding inductance manually, hence letting Altair Simlab do all the work. Is it possible?
Best regards
