Hello, running S-Frame 2023.1 and S-Calc 2023.1, i have made custom parametric sections in scalc, input their properties via custom database writer into custom database and able to apply the section from the new database to members in s-frame then code check in s-steel. However id like to be able to see the rendered section in s-frame, for visual and orientation purposes. When i try to export a .tbl file from s-calc it says its unsupported, any way around this?
