I am currently setting up a bending test simulation in Altair Inspire v2025 using SimSolid. The part consists of a hexagonal lattice structure embedded in a solid outer shell, modeled using implicit geometry and then combined with Boolean operations.
After using the Combine tool to merge the lattice with the solid block, I applied:
A fixed constraint on one end face
A vertical force on the opposite top face (intended to simulate bending)
When I attempt to run the analysis (e.g. normal modes or buckling), I receive the following error:
Both the fixed face and the force application face are shown in red.
My questions:
What is the recommended way to apply boundary conditions for a bending test on a merged (implicit + solid) geometry?
How can I prepare or partition the surface so that SimSolid recognizes it as valid for loads/restraints?
Thank you very much for your help :)
