I am currently learning Hypermesh2025. When using the export function of Hypermesh to export a solver deck for Radioss or OptiStruct, no file is created. Could you advise me on how to resolve this issue?
hi,
You need to do File → Export→ Solver deck to export a file in Optistruct/Radioss.
Check that you are using correct solver interface with .fem as extension to file name when using Optistruct.
Thanks…
Hi
If there are special characters in the name of the solver deck you want to export, I suggest you fix them and try again.
Thank you for your response. Unfortunately, it did not resolve the issue. If there are other possibilities, I would appreciate it if you could share them.
Is there any message in the lower left hand corner of HyperMesh? If there is a problem to export, it would normally report it there, can you try exporting to a different folder location, in case it is permissions related?
