Hi everybody,
When you have some data for an SN curve (or EN curve), theses curves are define for a survival probability (50%, 90% or 95% …).
It seems that you can't define this probability in the material definition.
So i assume that to perform a calculation at P=95%, you have 2 solutions :
- material data at P=95% and Std error at 0 and whatever the probability for the calculation (0.5- 0.95 - 0 …)
- material data at P=50% and a std error from material data (or by default) and a probability for the calculation fix at 0.95
regards
