I encountered an issue with a pressurized barrel.
To model the welding between two barrels, I applied different material properties to simulate the Heat-Affected Zone (HAZ). The mesh of this component is linked to the other component (with the initial material properties) through nodal equivalence. The geometry has the same diameter for both the HAZ component and the raw material barrel.
The pressure is uniformly distributed and applied evenly across the entire structure. Therefore, I expected the results to show homogeneous stress distribution for both the base material of the barrel and the HAZ. For the barrels, the stress distribution is fairly even, as expected.
However, for the HAZ component, the stress distribution, as you can see, exhibits a sort of repetitive pattern with a variation of about 100 MPa.
This result doesn’t make sense, and there seems to be an error. I’m unable to determine where it could be coming from. Do you have any ideas?
