Hi ,
I have a Two sets of gear, here I want to perform an FEA Analysis to find out the contact stress in the gear tooth using Simlab?
I have gone through the rack and Pinion gear tutorial in Hypermesh. But in my case, there are Bevel and spur type gears.
Which type of analysis suitable to find the above outputs and which type of contact should I give?
I attached the image for your reference.
Thanks & Regards,
Sivaprakash V.
