Hi, I have two drums that act as an axis and move a belt, which raises some buckets, how can I make this animation in inspire, or edem? I leave a photo thanks
Hi @Martin82,
This type of simulation will best be handled using MotionView, where the User can easily capture this model using several different approaches:
In Inspire, it is still possible to model a version of this system, but it would require a significant amount of planning as there is no Belt/Pulley Tool in Inspire. First, you would have to create the discretized belt yourself and model 'hinges' at every segment so the interface can detect the joints. Depending on the scale of this model, you may need to generate 100's or 1000's of these bodies manually. You would then need to create a series of contacts between the belt pieces and the pulleys with the high amount of friction.
Hope this helps!
Adam Reid
Ok, I'm going to try to do it in motionview, too bad because I wanted to keep the original drawing of the project, now I have a question, how do I animate the belt? With what function?Thanks
If you had already started a model in Inspire, you can easily export everything into MotionView. Inspire and MotionView are both preprocessors for MotionSolve, so the entity definitions can easily be transferred from one interface to the other. Simply go to the Run Motion Analysis window and Export » MotionView » Export .MDL File.
Also see below for an animation of the 3 different ways of creating a belt/pulley system:
Top (Discretized/Rigid belt)
Middle (NLFE belt)
Bottom (Coupled Joints)
By animate, do you mean how do you apply motion? Simply create a Motion entity on a revolute joint or a Force onto the pulley body to create the rotation of the belt.
If you are just getting into MotionView, Altair offers an introductory course, MotionView/MotionSolve Introduction eLearning, for solving multi-body dynamics (MBD) problems using HyperWorks and illustrates constructing, solving and post-processing MBD problems. This course focuses on general Multibody mechanisms and is a starting point for learning modeling in MotionSolve.
You can find it at the following link: https://learn.altair.com/enrol/index.php?id=496
Altair also offers a specialized multi-body dynamics (MBD) course for vehicle modeling, called MotionSolve for Vehicle Modeling eLearning. This class introduces the application of MotionSolve for vehicle modeling applications, such as assembly of half or full car models, vehicle event creation, generating event reports, modifying vehicle subsystems, and preliminary verification methods.
You can find it at the following link: https://learn.altair.com/enrol/index.php?id=497
Ok, thanks, I'll try and let you know if I have any questions. Thanks.
